Decathlon STILUS Full Suspension Electric Mountain Bike - SRAM SX
taxidriver50005
211
137
Skelmersdale
Errr nope
taxidriver50005
211
137
Skelmersdale
Yes there is! But... they told me the only store that can update the software is Croydon which is a bit of a trek for me but maybe ok for you ?
How do they do warranty work if no diagnostic equipment, would it invalidate your warranty taking it to another dealer or service center, the earliest version of bosch's software has a known few bug's so they must be getting a few warranty calls already.
20,902
if the bike is purchased online, are you still entitled to a free service?
Decathlon is Decathlon, if you buy on-line or in store. Some products are only available to buy on-line but the support structure & the return structure is all the same.
Mine was purchased on-line as it wasn't available for in-store purchase. But for problems, it was returned to a store. Eventual client dissatisfaction was also done by returning to a store where they also issued a refund.
slimsimmons1984
33
21
Bridgend
was it a stilus you had to return?
I don't have any decathlon stores near me to collect from, however there are plenty of bosch service centres near me including bike park wales,
question is will they charge for applying the new bosch firmware?
20,902
No, fear not :) It was one of the early e-st500's .. actually it was two of the early e-st500's ... they had water ingress issues into the crank sensor (now fixed I believe).
Dusty
251
106
Liverpool
Why did they cancel it? Did you ask for it to be delivered to a store that don’t accept Click and collect?
No just said be cancelled as none in stock they didnt take payment just seems theres mores steps to actually buying the bike than you would find on the great wall of china
Andyd68
70
24
Birmingham
Ok well my order is still in progress so taking that as good news.
So first questions (of many to come):
Does the bike come with pedals?
Do I need tools to adjust the bike when getting it out the box?
Also thinking of getting a multi tool, tubeless or Tannus Amour, pump and lock so any suggestions on on these without having to spend a fortune would be welcome?
I read through the previous threads as I know some of you have upgraded bike.
Many Thanks in advance.
PhilBaker
333
411
East London/Kent
Comes with peddles.
Tyres upgrade easily to tubeless if you buy tubeless valves and slime BUT you have to stand on the deflated tyres to get them to unseat from the rim to get them off. There videos on it otherwise you won’t be able to get them off. Good news though, is they are so tight on the rims you can pump the. Up with a normal track pump.
You have to mount the handlebars but it comes with some tools so nothing major to adjust.
My previous review shows the upgrades I made.
Congrats and good luck!
Idaho
49
47
Glasgow
Comes with peddles.
I live in Scotland but am French, so I always used to have my rear brake lever on the right of the handlebar. What was the brakes configuration when you got yours delivered?
If on the "wrong" side for me, do you know how easy are the hoses to swap on the SRAM Guide brakes (only ever had Shimano in the past)?
Again, it's just in case I get it delivered directly to my home, obviously if I can get the bike delivered in my local Decathlon shop I'll ask them to make sure it's got the brake levers like I need them to be...
20,902
@Gary should be able to advise the easiest and safest (not dot fluid everywhere). He speaks Scottish, French and bike.
Gary
Old Tartan Bollocks
10,496
10,705
the internet
you don't need to remove the hoses at all for swapping over sram levers.
SRAM use the same lever for left or right so you simply have to unbolt the lever bar clamps and swap the levers from one side to the other
Idaho
49
47
Glasgow
Amazing, and very well thought, will be fairly easy to switch if needed then!
PhilBaker
333
411
East London/Kent
Front brake is on the right, same as my other UK brought bikes but at least you know how easy it is to swap.
Just checked and the SRAM brakes are just as Gary suggested, completely the same on both sides, even the branding! Thanks Gary for the tip, didn’t know that!
20,902
It's great isn't it .. Everytime I've ridden on the wrong side of the road, I've just unbolted the handlebars and run them cow horn style with push brakes to get them on the right side. ..........
taxidriver50005
211
137
Skelmersdale
Mine also shows a cancelled item on the Web site but also one item different order number is in process but I only ordered once..... Have to wait till Monday to see what is happening
561K
