2023 Orbea Wild M10 Medium - DHX2 Coil spring rates?
scarl
42
sacramento
Curious what coil spring rates others are running? I like to think I'm an aggressive rider -I'm 187 lbs and found 475 a little to supportive / firm. Hard to explain but felt flat had to work hard to clear 12' gap. All shock setting set to Manufacture suggestions. I'm thinking 450 spring might bring bad some life.
so what spring rates are you running.
kombos
253
311
Arizona
145 lbs. running 350-400 progressive DVO on a Jade X.
Ride chunky desert, but not jumps/drops over about 3 feet.
Dirtyrig
47
8
New York
I'm 180lbs, 190 with gear, using a Marzocchi Bomber Cr with a 400lb spring, I get around 28% sag, 30% sitting.
578K
