• Warning!!
    UK Pedelec Law
    Worldwide Laws
Derestricting bosch smart system
Sir_Szendi
17
Poland
The Bosch website states the Performance Line Speed goes 45kmh. I wish we would have simple options to unlock that speed. Its annoying. Cars or motorbikes can go faster than the Speed Limit but the motors are not soft locked to the legal limit of 70mph. I don't know why ebikes motors are treated differently.
Anyway my chip works well so far so not too much of an issue.
I asked in the shop about the software with a 45km limit. They told me it was a different engine, but if I wanted they could change the engine to the one with a 45km limit. of course the price of a new engine is very high
martyfrommonmouth
20
12
Kent
I'm pretty sure they are all similiar internals - just software differences and form factor. Anyway - I can get 30mph out of mine but I'm pedaling like crazy....
martyfrommonmouth
20
12
Kent
I installed the bikespeed RS last night on my bike.
Delivery was quick from Germany but I had to pay an extra £36 for the import duty. So total price was around £210.
Very simple to install. Could do it in 10 mins now I've done it once. Just need to work out wire routing from the spoke magnet into the motor.
Had a scare when I first turned the bike on as it wouldn't register the motor - but I left it for a bit and after trying various fixes - (starting the bike with a bit of pedal / holding the power and mode buttons for 8 secs) it kicked into life and is operable whilst riding using the combo keys to turn it or off using my mode selector.
Now it just works immediately when I turn the bike on so hopefully won't have to worry about that issue again.
Took it for a ride and it worked perfectly. Need to properly test it later this afternoon but the difference is amazing from stock. The feeling of not riding into treacle at 15mph is so good...
I'll give more feedback later but for now it seems like an excellent solution - especially with the algorithm beating software (lets see if it actually works as promised).
I have got the Bosch Flow app and have tuned the motor in different modes but haven't signed up for an actual account or registered my bike so I'm hopeful I can still use the Flow app functions without causing issues, but if necessary I will just limit network access on the app or just disconnect from any data whilst using it.
I'll try that after using the bike for a while as my modes are all working as I want anyway so theres not really any reason to mess with it for now.
I did a decent ride to the woods and back home again and the chip performed well.
I did however lose power twice on the way home on the road and I think it is due to this function:
Hint for tamper detection
Bosch has introduced a significantly sharper detection of tuning
manipulation in their 4th generation motors. A standard tuning is typically
detected within a very short time, causing the motor to indicate
manipulation and switch to a limp-home mode with reduced motor
power or completely shut down motor assistance.
This state can be reset by riding without tuning. According to Bosch, this
may require up to 90 minutes of driving. Alternatively, the error memory
can be cleared by the bicycle dealer.
We have developed an algorithm to prevent this detection. During the
development of our tunings, we have extensively tested them over
several thousand kilometers to ensure that you can enjoy your pedelec
without any restrictions or error messages. Despite all our efforts, there
remains a small residual risk that under certain circumstances,
manipulation may still be detected. Therefore, please take note of the
following system-specific changes:
With the Bosch Smart System, it is possible that after a long ride at a high
speed, you may enter a critical area where the tuning can be detected. If
our tuning detects this situation, the motor assistance will be limited to
30 km/h. This limitation will be automatically removed as soon as the
technical conditions allow. This limit is additionally indicated on the
bikespeed display by a yellow bar at the top edge.
It was quite jarring. I have emailed the bikespeed guys and asked them if there is anyway to avoid this but I think its unavoidable due to the Bosch Detection algo.
The main thing is I suppose, is that the tuning has not been detected, but worth bearing in mind that this will affect you if you are on a longer ride continously at high speed with this chip.
martyfrommonmouth
20
12
Kent
did you completely lose power, or just over 30km/h?
Do you know what, I can't be sure to know as I turned it off immediately and rebooted the bike as I was on a 3 lane fast road and needed to keep with traffic.
I will test again (with a speed app) and let you know but I think it was that it felt like I lost power as I was way over 30kmh and suddenly I was trying to pedal along with no assist.
Trickz
294
283
Burton upon Trent
I’ve wasted 14 hours of my life messing with a speedfun gen 5 evo kit,did everything possible including going way and beyond to prove the fact it was not working for my particular bike by having the replacement sensor on a flipping bit of wood 300mm past the rear axle..as they kept saying it’s needs to be futher away from the Bosch internal sensor,it would either work for a min over 25kph then get the orange light on controller or would just hit the 25 an restrict..currently trying to get my money back from the supplier
martyfrommonmouth
20
12
Kent
Damn - so annoying.
My bikespeed RS works - just note there are limitations but at least bikespeed tell you these beforehand and they can only do so much to combat Bosch. Without source code and access to the bikes motor firmware there's nothing much anyone can do except work around the limitations of the Bosch detection algorithm.
To be honest I'm already thinking that in a couple of years I will get a bike with a DJI motor as they can be derestricted easily by just setting your location i.e. New Zealand using a VPN.... Bosch are making it too difficult and invasive - it's my bike and motor - if I want to ride it at high speeds I'll take the risk and the consequences. Thanks all the same Bosch police.
Joecrow
71
33
Munich Germany
Bear in mind that if Bosch and the other manufactures don't make it difficult and too many people derestrict their E-bikes it won't be long till someone in government decides that all E-bikes are not ordinary push bikes and need to registered, taxed, inspected regularly and have a number plate. Don't screw it up for everybody!:(
Naagra
8
France
I think guys you need to check the Mountain tunning (MTT) its very popular in germany with ZERO errors so far ! (11 000 KM Winora Gen 4 Smart System with mine and no issues (524 or 504) : MTT Smartchips V2
Do know why it's not popular here, it's the perfect solution
They have developed a new solution for rim magnets/gen 5 : RIM BOOST V2 (Sorry it's german but you can use Deepdl or Google trad) EBIKE TUNING BLOG RIMBOOST V2
I really recommended to read this german/forum threads, they provide lots of useful informations : Bosch Tuning Smart system
Not Cheap but better than the crap Speedbox &
https://www.ebiketuningshop.com/col...ng/products/rimboost-v2-38-bosch-felgenmagnet
martyfrommonmouth
20
12
Kent
RimBoost V2.38: für Bosch BES3 mit Felgenmagnet (BDU38)
Same as all the others - no guarantees....
No Bosch tuning detection
To ensure that the notorious Bosch anti-tuning software doesn't affect this tuning product, extensive test drives were conducted. any The Bosch system did not detect tuning, and no error messages were generated. To the best of my knowledge, RimBoost V2.38 seems to be immune to all current anti-tuning measures.
But please note: There are now indications that the infamous Bosch error message "524001" can occasionally occur even without tuning. Therefore, we cannot give a 100 percent guarantee that this error message will not occur. However, it did not occur during any of our test drives. Nevertheless, we cannot completely rule out the occurrence of a 524001 error.
martyfrommonmouth
20
12
Kent
Yeah - it's a stupid situation in general with arbitary rules that are different in every country... the whole thing is bit ridiculous considering:
During Tour de France sprints on flat sections, riders can reach peak speeds of 70-75 km/h (48.47 mph), with some sprinters like Mark Cavendish reaching even higher speeds.
On relatively flat stages of the Tour de France, professional cyclists typically average speeds around 25-28 mph (40-45 km/h)
martyfrommonmouth
20
12
Kent
Second decent ride today until I did a huge downhill run (with some very rough bumpy sections) and hit 40mph (well according to Strava) and when I got to the bottom the Bosch system controller in the frame went Orange. I had very limited assist. Barely anything. Limp mode activated. Rebooted the bike and got assist for 3 secs and then flashing Orange light. No more assist (well basically none - like 1mph assist) for me and day ended short...
Got home checked the Flow app and error 523001
Speed sensor not working correctly so something has triggered it as it is in the same position since being installed. I'll remove the derestrictor tomorrow and put back the original magnet on the Rim and see if that resolves the error.
I feel like selling the bike and getting an Amflow with DJI (wish I had in fact) but didn't find out about them until after I bought the Cube with Bosch.
Speaking with Bikespeed.de so I'll see what they say... maybe it's easily resolved but thats 2 rides and 2 lots of errors.
<RANT> It really shouldn't be this hard to derestrict the bike - I was in a private woodland. I should be able to ride the bike how I want... </RANT>
575K
