calnearlyebike
What sort of compression tune do these stock Ebike zebs come with ? Are they just set the rebound and go and feel great ? The trek looks like a rocket ship
Your Levo has better integrated battery, it plays big role on weight. 55lbs is not bad for 800 battery, IMO.Well, IMO Trek dropped the ball, again. I really wanted the new Rail + with the Gen 5/800wh battery. I dont understand how the bike can be so darn heavy. Im seeing 55-56 lbs depending on the build. How can this be when the new motor and battery are about 2 lbs lighter? Im not a weight weenie guy, but I have to lift the bike over logs on the trail a lot. Our trails are remote and we see a lot of downfall. My Levo is 49 lbs. Ya 5-7 lbs isn't much but come on Trek.
No right or wrong answer......a guy I know will 'show off' about how little battery he has used on any given ride. I have the opinion that the perfect ride is where you finish with as little battery power left as you dare.Really Enjoying the new bike . cant really get my head around the modes. Only used Eco and Tour + . I climbed a fairly steep hill in Tour+ and felt more than enough . This is the first ebike , im i ok to just use the lower power modes, or should i put it into the Emtb or turbo modes for big climbs? or is it a case of use it if you need it ? The mind boggles as your cruising up a hill you were pushing up a few weeks ago
I like to "earn my turns" so I mostly climb in tour+ unless its over 20-25% grade then use EMTB. I never use TurboReally Enjoying the new bike . cant really get my head around the modes. Only used Eco and Tour + . I climbed a fairly steep hill in Tour+ and felt more than enough . This is the first ebike , im i ok to just use the lower power modes, or should i put it into the Emtb or turbo modes for big climbs? or is it a case of use it if you need it ? The mind boggles as your cruising up a hill you were pushing up a few weeks ago
Man that charging port is a real eye sore compared to the previous gen. I'm sure they have their reasons, but looked much better when it was flush with the frame.Charge port cover , is everyones like this . Really poor design . Was thinking about a 3d printed insert ?
Tour+ uses your modes from eco to turbo automatically so keep ridingReally Enjoying the new bike . cant really get my head around the modes. Only used Eco and Tour + . I climbed a fairly steep hill in Tour+ and felt more than enough . This is the first ebike , im i ok to just use the lower power modes, or should i put it into the Emtb or turbo modes for big climbs? or is it a case of use it if you need it ? The mind boggles as your cruising up a hill you were pushing up a few weeks ago
Bike rides great . I have it in the high setting. Just about to bump the forks up to 170mm as wellStill no real in-depth reviews from the mainstream mtb media, but here is a nice ride review from South Africa:
So I don't get why there isn't more hype about this? What other Bosch Gen 5 800Wh bikes are there with an _easily_ removable battery. Pretty sweet I reckon.
The bike is proper. Rides very well. People hate the looks mainly.So I don't get why there isn't more hype about this? What other Bosch Gen 5 800Wh bikes are there with an _easily_ removable battery. Pretty sweet I reckon.
On the old rail I know a lot of people over stroked the shock, but on this it looks like it is already 65mm so no possibility for more than 160mm rear?
I think it looks great. Fact is it's just hard to package an 800Wh battery without some bulk.The bike is proper. Rides very well. People hate the looks mainly.
In the high position travel is 163mm - with a 170mm fork and some better brakes it’s brilliant. (Have tried in this setup with full Ohlins )
Would be good to see what a coil is like on this Rail +… recently bought a vivid coil for my Levo and I’m a convert and Rob? what’s is happening to the recharge podcast?The bike is proper. Rides very well. People hate the looks mainly.
What is it with bloody mullets?Ride from the house budd and we have loads of stuff on our doorstep... Yeh has 2 flipchips one for low/high and one for coil/air but there is no clearance for a 29" wheel
What don’t you like about a mullet bike?What is it with bloody mullets?
not good if you cannot put a 29 on the back,same as speccy levos,virtually all mullets,do manufacturers not realise some of us dont like them![]()
Why Mullet? Explicitly?What don’t you like about a mullet bike?
The look for a startWhat don’t you like about a mullet bike?
If i wanted to ride a penny farthing,id buy oneThe look for a start
Put some tape over itCharge port cover , is everyones like this . Really poor design . Was thinking about a 3d printed insert ?
