2023 Orbea Wild
DrDexx
57
63
Longridge
Sorry, I'm sure this has been asked before but I have recently picked up a Wild size medium 2024 model. Can anyone tell me if this particular shock fits the frame. It's a 205x65 Rock Shox Super Deluxe Coil Select R or would I be better off going with a Fox DHX2?
Also, in terms of spring rate, I am 76kg on a good day, is a 450lb spring the way to go?
Not too sure if that one will fit, Someone on here will know. I use a DHX2 and that fits fine.
I've used the below from TF Tuned for years for calculating spring rate, and its always done me good.
For reference, I'm around 100KG and use a 475lb (sometimes 500lbs) spring.
curious_george
Ireland
Perfect, thank you. The fox sounds like a safer bet.
ScubaDrunk
11
So am i hearing this right?
A Fox DHX2 will fit on a 2023 Wild without any modification needed?
DrDexx
57
63
Longridge
Yes, maybe on a small frame there might be an issue. But on my XL there is loads of room.
ScubaDrunk
11
Thanks for getting back to me so quickly. Thats awesome to know.
What size did you go for out of interest? I also run a 2023 Wild XL, so keen to purchase the right size.
When I emailed Orbea, they replied with the default NO it would not be compatible.
Thanks again
DrDexx
57
63
Longridge
Thanks again
The shock will have to be 205mmx65mm trunnion mount.
Yeah Orbea are not very helpful at times!
DrDexx
57
63
Longridge
Strange - Fox don't list a 205mmx65mm trunnion DHX or DHX2 on thier website for purchase?????
Here a performance elite one.
You can also get a 205x60mm trunion and remove the stroke reducing spacers. It's a very easy job, you don't need to take the shock apart.
Like this
ScubaDrunk
11
Like this
Thanks again. Really appreciate your replies and help.
Yeah I just spoke with Sport and Leisure and the Elite is the version that comes on pre-built bikes so all good with that,
Cheers
DrDexx
57
63
Longridge
Cheers
Yeah, I think the only thing that one doesn't have is the lock out, which to be honest, is pointless on a ebike.
Enjoy!
curious_george
Ireland
Anyone find that it very easy to lock up the back wheel on the wild when riding steep loamy descents. It is the calmest bike I have ever ridden for descending but I am finding that it is very easy to lock up the back wheel which I haven't experienced on my other bikes with the same minion dhr2 maxxgrip tyre. I have been experimenting moving my weight fore and back but whatever it is about the bike, it just seems to love the back end stepping out.
6,846
5,290
Back brake on steep descents is always going to be that way because rider and bike weight is pushed forward on the bike....and applying the back brake increases that forward weight. One answer is to make more use of the front brake preferably together with the back brake. You can also help achieve a more central weight balance with cockpit alterations such as higher rise bars , shorter stem etc....whatever raises your torso when up on the pedals taking some weight off the front wheel.
Dirtstache
13
Atlanta, GA
Which brakes and shock do you have? I found it much easier to control lockup when I upgraded to the TRP DHR brakes and instantly noticed better braking traction when moving to a coil shock.
curious_george
Ireland
I'm using SLX brakes with 200mm rotors. I think it's definitely a positioning issue but I have a ripmo with a very similar reach and same tyres/brakes setup and it's far less prone to locking up.
davosaurusrex
621
370
Worthing
I agree that it's tail happy compared to other bikes. My local trails are steep and often loose and on the steeps into turns it's pretty lively. I'm on an XL and think the chainstays are a little short, certainly is compared to previous Mondraker Crafty. Guess that's the trade off for it being poppier and faster turning
I'm running an EXT Storia coil, I found slowing down the rebound has helped a fair bit. I'm also a lucky boy, running Trickstuff Maximas. The modulation is incredible so it's not the brakes!
pdqmach26
10
Laguna
How about reducing your rotor size or put resin pads in your rear brakes.
6,846
5,290
virtually any brake set up will lock up a rear wheel on a loose descent and traction is mostly down to how much weight is on the back wheel. If the bike centre of mass..fore and aft.....is more forward you can only compensate by moving your rider weight further back on the bike.....and making better use of the front brake....but only when the front wheel is straight!!
davosaurusrex
621
370
Worthing
Thanks coach.
Some bikes ride differently to others shocker. The Wild is quite tail happy IMO, makes for good scandi flick practice though, usually because you don't have a choice!
575K
