Amflow Customer Support team is here!PLEASE feel free to leave your comment
Dave238
22
13
WA
Thank you for your confirmation. Regarding this issue, please kindly try turning the circled screw in the picture clockwise. If the situation does not improve, please let me know. This is the screw next to the wireless shifter on the seatpost. View attachment 154188
So for the PL Carbon, to remove the seat post you have to cut the cable, which according to the pic includes cutting the housing too? I realize the seat post removal isn't a regular thing but that seems excessive considering the other version has a simple bolt. I haven't had much exposure to many bikes, is this a standard practice?
David1960
67
49
Msnchester
We’re excited to join this fantastic community! We are the Amflow Customer Support team, dedicated to providing top-notch assistance and innovative solutions for E-MTBs. Our mission is to ensure that you have the best possible experience with our products and to support you in any technical challenges you may encounter.
Wondering if you can help me decide. Not sure whether to get the pro version or basic model of amflow. Is the difference worth it. Does the pro version perform that much better than basic model. Is suspension a noticeable difference.
iXi
497
396
Brisbane
Probably comes out of the Amflow box with no carbon paste (dunno, my bike shop did the assembly)?
Anyhoo, I had the sinking seat at spec nm. I reckon it’s a sign of correct tolerances. A lick of carbon paste and a modest tightening solved it.
Hmmm so got the carbon paste and tightened to 6nm and by the end of my ride had slid back down. Not sure if I should go 7nm or just suck it up and ride it 10mm lower than ideal. I'm probably going to lock in option 2
Amflow_Support
Amflow
117
136
China
If you are a casual rider or just starting out, the Amflow PL Carbon should meet your needs without the extra cost of the Pro version's high-end components. However, if you are looking for a more professional riding experience with lighter weight and higher-end components, the Amflow PL Carbon Pro might be worth the investment. You can see the comparison information about suspension and other parameters on this page Amflow PL - Specs - Amflow (United Kingdom)
Amflow_Support
Amflow
117
136
China
Have you tried turning the screw in the picture clockwise? Did that help with the issue?
Regarding the seat post removal, you do not need to cut the cable. Could you please clarify if you are looking to replace the seat post?
We appreciate your feedback and are here to assist you with any further questions.
  • Like
Reactions: EME
Dave238
22
13
WA
I was referring to your posting you included a picture of the seat post removal that indicates for Carbon PL the cable and housing has to be cut.
Astro66
Golden Boy
May 24, 2024
515
966
Sydney Australia
When you undo the screw under the trigger. The cable can't slide out, because there is usually a cable end clamped onto the end of the wire. So you cut the cable just before the cable end. That way you can reuse the cable. Then the cable is free to fully slide back into the sheath.
But you should be able to unhook the cable at the post end, without cutting. Just undo the screw under the trigger, undo the screws holding the cable sheath to the frame, and see if you get enough slack to unhook the cable at the post end.
Amflow_Support
Amflow
117
136
China
I'm referring to this in yellow for that model. View attachment 154370
For the PL Carbon, if you need to replace the seat post cable, we recommend following our manual's instructions to cut the cable for easier handling. But if you're just looking to remove the seat post from the frame and keep the cable intact, there's no need to cut it.
Dave238
22
13
WA
OK, it sounded like (from the pic) to remove the seat post from the frame, the housing and cable had to be cut. Thx for clarification.
Pete66
Spain Almeria
I managed to rip my mech off completely yesterday & also destroyed the hanger on a large rock at the same time. Does anyone know where I can get a new hanger please ? I have looked on Amflows site & they‘re not shown.
Bike is the standard PL not the pro.
Astro66
Golden Boy
May 24, 2024
515
966
Sydney Australia
It does appear to be a standard SRAM UDH hanger. Should be able to get it from most bike stores.
JonoHobart
7
Tasmania
Can anybody tell me if I need to change the free hub body on the PL carbon version, ( Amflow HMA-30 wheelset) If I am going to put on a SRAM 1295 10 to 52 tooth cassette?
I am considering upgrading to T type AXS transmission given that I already own a rear derailleur and the shifter.
Astro66
Golden Boy
May 24, 2024
515
966
Sydney Australia
If you go to the Accessories page on the Amflow website. You can buy a new rear alloy 29er wheel. And in the photos. It definitely has a HG Hub. Whilst the rear Carbon 29er for the Pro, has a XD hub.
You definitely cannot fit a 10 tooth cog on a HG hub. So you will need to change it to a XD hub to fit that cassette.
JonoHobart
7
Tasmania
Thanks. Pretty much what I thought, but does it have to be Amflow wheel specific, or can it be any SRAM XD freehub body?
Astro66
Golden Boy
May 24, 2024
515
966
Sydney Australia
I build my own wheels, so normally I just buy an entire XD hub and freewheel assembly, of any brand, and re-spoke the wheel. So yes. If you change the entire hub assembly. As long as it's an XD Hub. It can be any brand.
I'm unsure how easy it is to change the HG freehub only, or even if it can be done. And what brand of XD freehub will fit that hub assembly. It is Amflow's own wheel.
JonoHobart
7
Tasmania
Thanks, I’ll await any further advice from others before jumping into buying a new cassette. Apparently XD freehubs are in the order of AUD70, but that of course assumes you might be swapping like for like, as you say, not sure if you can do an automatic swap for the HG free hub body.
Amflow_Support
Amflow
117
136
China
Hi JonoHobart, Amflow makes all the wheelsets, hubs, and freehubs for the Amflow PL. If you want to make some changes, and need the AMFLOW HMA-30 XD Freehub. Just drop a line to our customer service at [email protected] with your shipping info, and we'll creat a freehub purchase case for you through our after-sales service. Thanks for your understanding and support!
knocknock123f34
Italy
Dear @Amflow_Support,
As a passionate cyclist, I rely on my Garmin device to track and analyze my performance. However, one crucial feature that is still missing is the seamless integration of cycling power data. Power measurement is one of the most accurate and reliable metrics for assessing training efficiency, monitoring fatigue, and optimizing performance.
Integrating power data directly into Garmin devices would offer several benefits. First, it would allow cyclists to analyze their wattage output in real-time, enabling them to adjust their effort more precisely. Second, post-ride analysis would be significantly improved, helping athletes and coaches make informed training decisions. Finally, better synchronization with training platforms would ensure that all data is stored in one place for a comprehensive performance review.
Beyond the technical advantages, this integration would make the bike much more attractive to potential buyers. Cyclists who train seriously rely on power data to improve their performance, and having this functionality seamlessly connected to Garmin devices would be a major selling point.
Thank you in advance
turandot
22
11
Spain
I would like to know if Amflow has introduced any improvements in the e-bikes in the manufacturing process, from the beginning of the first unit until today, based on the comments of users on forums and social networks. Thank you.
Bigjohnmtb
8
48
Hong Konh
Hi,
I have the Carbon Pro model with the XO T Type drivetrain. On the SRAM website it says the chain length is 118 and the derailleur is set in position B.
When I received my bike the chain length is at 120 and derailleur is set in Position A. So what is the correct length and position pls??
Amflow_Support
Amflow
117
136
China
Thank you for your detailed feedback and suggestions. We appreciate your insights and passion for cycling.
Currently, we have tested and confirmed that Amflow is compatible with Garmin heart rate monitors. We will continue to conduct further tests regarding additional integrations and functionalities.
Thank you for your valuable input.
Amflow_Support
Amflow
117
136
China
Thank you for your interest and attention. At Amflow, we highly value our users' feedback and experiences. For example, in response to customer feedback regarding the limiter block issue, we will be introducing related accessories in the near future.
Amflow_Support
Amflow
117
136
China
Hi,
Hi there, we have noticed that there is a discrepancy between the information on the SRAM website and our setup. However, we have confirmed with our engineers that having 120 links and the setup key in position A is the standard configuration for your Pro model. There is no need to make any adjustments.
Please rest assured that your current setup is correct and safe. If you have any further questions or concerns, please do not hesitate to contact us.
prrave
14
12
Hi Amflow I have the normal silver PL model. I have equipped it with the Sram Transmission GX. Should I also change to 120 chain links and position A. I currently ride the SRAM recommendation, i.e. 118 chain links and position B. I have to say that the gears work. Thank you for your reply
Amflow_Support
Amflow
117
136
China
Hi prrave, Amflow PL Carbon comes with a 120-link chain, position A, and a 21T rear hub. If you change the cassette or chainring size, you'll need to adjust the chain length. For example, going from 34T to 36T means you should add 2 links. We suggest having a professional bike shop handle these modifications.
Budi
16
France
Hi there, we understand that you need to purchase the required power cable. This power cable is provided by SRAM and is not a custom design by Amflow. You can purchase this cable directly from SRAM, and the material number is 11.3018.028.003. If you have further questions, please send an email to [email protected] or use our chat service on our website :)
Best regards
Amflow support team.
Hi, is this the right cable?
571K
