Well my favoured Öhlins RFX 38 forks are with J-Tech for a warranty claim (they’re only 10 months old and need a new CSU!), so I’ve bought a set of crowns to put the double crown Öhlins DH38s from the DH bike onto my KSL.
It’ll be interesting to see how it rides with 200mm up front, over stroked to 65mm on the rear, and absolutely no steering lock.
the 2022 Fox Float X2 that came with the frame ... failed after 6 miles ...
Big bore valves, sounds sexy, will they give more torque?Muc off Large Hybrid Big Bore Valves in orange
I did exactly the same. Fake arse shit.Update! Seller (somehow) messages, offering a £3 refund & I can keep the gloves. Me: Get F***ed.
The perfect recipe for peak performance.New chain, new galfer pads, topeak digital pressure gauge, torque wrench, carbon paste and peaty's bike cleaner![]()
Swapped my cheap & nasty oem lower headset bearing for a sexy sealed cartridge. To my surprise, Chain Reaction have kept their Ebay store going, so bagged a ZS56/40 lower cup, bearing, seal & crown race for £8. Acros, Hope etc are four or five times the price & the Nukeproof stuff is easily similar quality.
That is good to know that Chain Reaction has the E Bay store.
They look awesome them jacketsA Dfyrs ripknot waerproof Jacket and free pair of socks
While I'm not going to disagree with you here ( I don't know too much about them ) ..isn't the main advantage in the fact that they give a much larger contact patch to the ground when running at the same pressure ..and if I've read the blurb correctly it's recommended that you run the same psi as comparable non radial tyres to start with ?Far from it. At 30psi they feel like a normal tyre does at 20. That's kinda part of the whole point.
I have been eyeing them up for a while, finally decided to buy oneThey look awesome them jackets
Dunno if it counts as "bought" but Fox have just confirmed they're sending me a brand new 2024 Float X2 Factory as a warranty replacement for this oneUnfortunately my Ohlins coil shock is also still off being serviced so I had to ride the 2022 Fox Float X2 that came with the frame. It’s the first time it’s been ridden and the damper failed after 6 miles so it was bottoming out constantly despite 200psi (I’m 50kg). Off to Fox it goes…
