Hybridizer Sann Bafang M500 series Aluminum FS
Tomblarom
145
215
@D'Apostrophe spotted the new Hybridizer frame!! Source: Bafang Facebook Page
An employee of Hybridizer is also there. 😁
D'Apostrophe
18
29
California
What is your current build and weight? I'm curious how light they could get an aluminum frame.
I threw caution to the wind when it came to weight. I'm 220lbs (99kg), so a light weight bike doesn't really matter.
The build is 58lbs (26kg)
27/29 crankbrothers synthesis Alloy wheels
Schwalbe eddy current tires 2.6 and 2.8
220/203 rotors
Sram db8 brakes
Fox 36 fork, Fox dpx2 shock
Sram XO axs t-type
Rockshox reverb dropper
Ergon smc large saddle
Crankbrothers stamp 3 pedals, large
Raceface turbine stem and aeffect bars
Cane creek headset
Fidlock bottle
Tomblarom
145
215
Received mine a few days ago. I'm amazed and very excited, to finish the build.
However I'm working on some custom features, like cable duct for the rear light and custom wiring so I can attach Lupine SL X + Lupine C14. It's a rather slow build, but I try to post images regularily.
Tomblarom
145
215
I got this "WILDMAN" bag from Aliexpress. The ugly reflective logo and straps can easily be removed. For mounting I made myself some 3D-printed parts, that screw into the exisiting screwholes of the frame. The zippers had to be replaced with cords, since it's hard to get around the corners otherwise.
Tomblarom
145
215
Just finished building the wheels! It's down to centering them now.. :)
Front: Novatec Hub 110mm Boost 32H 6-hole [D041SB-B15]
Back: Novatec Hub 148mm Boost 32H Shimano-body [D462SB-SL-B12]
Rims: Rodi Blackjack READY40
Spokes: DT-Swiss Champion 2,34mm
EFEEVO
14
17
Slovenija
I finaly build my bike. It is verry nice bike frame, and works very good.
I have ordered bashguard and adapter for accustic bottom bracket (to make non electric bike bb92).
Price for chain guard is 52$, price for bottom bracket adapter is 100$, shipping to EU is 45$. And they gave me free jersey😁.
I think all parts are super nice.
Have a nice day. 1713515814066.png 1713515779245.png image.png 7fd6c19c95ea4ea360e703535df30d8.jpg 3a46e1ef9e7ef8968bb3fcdd3242aee.jpg eb9354e504e6b08099e94e62b0fc24e.jpg
Tomblarom
145
215
I designed it so that it fits the carbon tube and replaced the lower part with a 3D-printed part to fit the new BMS and charging connector. I used silicone to glue it back in. Here is it compared to the stock battery.
Bozzma
The Netherlands
I was looking for te DengFu E82. I thought I didn't need this high pivot kind of tech. But it all seems to be thought out well by some true EMTB geeks (ment to be a positive thing). The manual is interesting. So.. I am very interested in this bike.
Sadly it will take to long to get here to use it this summer. So I got me a cheap non e-motor Scott for the summer to enjoy the flat Dutch trails. I might order a Hybridizer later on to build as a winter project.
I just stumbled on a new 2024 release clip from Hybridizer. One of my main concerns was battery capacity, but they have enlarged it a bit to 860Wh. They also mention an upgraded bearing part in the rear suspension.
It is also available with the 500W M560 (130Nm). The 750W power plant is NOT supported, the battery's BMS wouldn't supply that much current. I would think the 500W motor would be able to burn through the charge fast enough, so it will do for me.
I hope more Hybridizer Sann owners will leave a comment on their experience with building and riding this nice EMTB!
The 2024 release video of Hybridizer.
Alessio77
28
34
Canary Islands
Very nice frame ! I'm new to ebike world and considering the Sann as first build; its manual mention the speed sensor, but I can't see the cable running in the swingarm...
Charging port is located just in front of the motor area?
Tomblarom
145
215
Does anybody need a backup battery? Since I built my own battery, I no longer need this one. It was just for backup. 😊 I'm asking for 650€, which includes charger + battery. Send me a message if you're interested.
EFEEVO
14
17
Slovenija
If anyone is thinking about buying a Hybridizer bike, I want to say that the bike is great. I also bought an adapter for bike parks (for a regular crankset without a motor and battery). The bike works really super.
Even with some problems and issues, the Hybridizer team is very responsive. They answer emails quickly and fix problems professionally. If you're unsure about buying a bike directly from Asia, you will be happy with Hybridizer.
Klemen
pzw
Poland
Hi.
Could anyone share about Hybridizer Sann build please.
I'm looking for:
1. Front fork
2. Derailleur
3. Cassette
4. Damper
5. Brakes
What did you use or you are going to use?
Thanks.
Blue83
Deutschland
Hi.
I'm looking for:
1. Front fork
2. Derailleur
3. Cassette
4. Damper
5. Brakes
Thanks.
Marzocci Bomber Z1 180mm
SRAM GX 11 Speed groupset
Fox dpx2
SRAM code silver stealth
  • Like
Reactions: pzw
EFEEVO
14
17
Slovenija
Hi.
I'm looking for:
1. Front fork
2. Derailleur
3. Cassette
4. Damper
5. Brakes
Thanks.
1. Fox 38 factory grip 2
2. Sram gx 11s
3. Sram 1175 cassette
4. Rock shox super delux ultimate or xfusion h3c
5. Hayes dominion a4
579K
