TQFreak's Dengfu E55 Build Thread
TQFreak
180
236
I ordered an empty battery case on aliexpress, still waiting for the frame to be shipped but dengfu has delays...
I partially disassembled the battery supplied with the frame. Here is the process
The charge level indicator connected to BMS with 4 wires. I'm wondering if it is possible to replicate this functionality with different BMS for custom build battery?
They use something like white color silicone glue or maybe soft potting compound to secure the wires and the battery pack. The battery pack is protected with a few foam pads from contacting with the aluminum extrusion tube and glued with the same white rubbery stuff in the aluminum extrusion tube so I decided to not pull it out to keep it secured with the glue.
TQFreak
180
236
You're right. If not then I can somehow have one fabricated for me.
Could you please also make one photo of the inside of the downtube. I want to understan if there the same 2 bolts that hold brackets securing all the housing.
Thanks!
Here is the part number for the plastic cover (Reention PLA0561). Maybe it will help you to find it.
Here are the close pictures from the inside of the frame downtube
Bottom of the downtube view from the motor area
Bottom of the downtube view from the battery area zoomed out
Bottom of the downtube view from the battery area zoomed in
Top of the downtube view from outside
Top of the downtube view from inside zoomed out
Top of the downtube view from inside zoomed in
TQFreak
180
236
OK, I just printed the Kindernay shifter torque arm out of polycarbonate on an FDM 3D printer and it fits and works without issues. So if you are going to install Kindernay gear hub on Dengfu frame you can 3D print this part and fix the shifter housing with it. I would recommend you to use polycarbonate or PETG filament.
Here is the link to downaload the 3D file of the Kindernay shifter torque arm
You also are going to need a stainless steel M5x16mm screw
and a a stainless steel M5x10mm OD washer
Apply Loctite blue and install it
TeoElFeo
185
63
Tallinn
Thank you for the detailed photos, they have been very informative!
Would it also be possible to measure the distance from the rear(motor) wall of the downtube until the ridge that is in the upper part of the tube. Basically trying to figure out how much flat space is there available for calculating custom batterypack size.
TQFreak
180
236
Here is some information about the Innotrace X2 display for the Innotrace X1 controller can be helpful.
The Innotrace X2 display advanced settings are locked by a password. The advanced settings allow you to set the correct wheel diameter and pedal assist speed limit.
Innotrace still did not respond me about how I can reach those settings but I figured out it myself after sore research.
Here is Innotrace X1 (Eggrider) display manual, it has some similarities to Innotrace X2 display (Intelligent OLED Display DM03) and finctions
Here is the Innotrace X2 (Intelligent OLED Display DM03) display manual from the OEM manufacturer
To enter the display settings menu on Innotrace X2 display you have to turn the display ON and then press and hold the "M" button withing first 10 seconds after the display is turned ON.
Then you go to the "ADWSet"
Set the password 1657
And now you are in the Advanced Settings menu
Set your wheel diameter
Set your pedal assist speed limit
And here are all the advanced settings password combinations I found in the internet for Dengfu motor powered bike displays you can try in case the one I posted will not work for you so maybe you don't need to try 10000 combinations to find the one
1657
1919
1199
1801
0512
0486
0000
TQFreak
180
236
Here are the sizes. The distance between the ribs is 483mm. The opening length is 435mm. The distance between the bottom edge of the opening and the rib at the motor compartment is 24mm
Also pay attention the upper rib goes not straight vertical along the whole height, it makes turn, but that turning portion in opened up. The open portion of the rib which does not go straight vertical is about 71 mm. If you can squeeze the battery in this space you can probably ignore this rib turn
TeoElFeo
185
63
Tallinn
Thank you for taking the time and giving those measures! Perhaps I didn't clearly explain which part I meant so I will try again.
I wanted to ask about the distance between the inner side of the motor rib and the very begining of the upper rib.
In fact I think the battery shape will follow the upper rib so I am trying to figure out how many rows of batteries I can fit before having to make the odd shape placement. Also what is the inner width of the downtube?
TQFreak
180
236
If you will be able to squeeze the battery somehow through the lower rib opening to the motor it will add 19mm. Here is the distance between the lower rib to the motor. So you will have 483mm+19mm=502mm between the motor and the upper rib.
The inner section of the downtube is 115mm x 84mm. There is also a couple of glued bottle mount inserts protrude 10 mm inside the internal space of the downtube
The odd shape upper rib is about 45mm wide if measured along the downtube length
TeoElFeo
185
63
Tallinn
Thank you so much! Now I have all the measurements needed.
Also wanted to ask if the grey cylinder in between bottle cage mounts is a threaded mount for cable routing bracket?
TQFreak
180
236
There are two grey cylindrical threated mounts for the two aluminum brackets supplied with the frame for cables routing. They occupy about the same 10mm height with attached aluminum bracket as the brown bottle mounts threated cylinders.
TeoElFeo
185
63
Tallinn
Perfect. I was planning to use them to attach straps to the frame that will hold my custom battery.
In theory I should be able to fit 48v 30ah battery. In practice I will find that out in a couple of months once I get the frame 🙂
TQFreak
180
236
Kindernay VII shifter hoses are not long enough, so I purchased 10 meters of 2.0*5.0mm hydraulic hose
In order to have access to the swingarm cables holes I detached the lower mound of the swingarm.
The holes for the cables in the swingarm allow to route only one cable. Kindernay shifter requires two hoses. So I enlarged the right cable opening with Dremel
Then I enlarged the original hole
And drilled another hole for second hose near the first one starting from small drill bits and following ladger drill bits
So now I have two holes large enough to route two hoses through the swingarm
Cleaned the carbon dust with vacuum cleaner
Pushed 2 hoses through the swingarm and picked them from the swingarm opening
Cut both hoses with extra length from the main spool
TQFreak
180
236
The nest thing I did is I routed the Magura MT5t brake hose through the left side of the swingarm.
Attached the brake lever to the handlebar so the hose goes up
Clipped the brake hose off at the brake lever
Plugged the hose with the plug supplied with the Magura brake kit
Clipped off the plug head so it will not interfere with the mall channel in the swingarm
Attached the cable frame grommet supplied with the frame to the hose
Routed the brake hose through the left side of the swingarm
Routed the Kindernay and the brake hoses through the brame and hanged the brake hose at the high point so it will not leak with oil
Clipped the hose grommet to the place
Attached the swingarm back
Attached the rear brake caliper
Then I cut about 200mm of flexible plastic tube (4mm inside diameter, 6mm outside diameter) and cut at along the length
And attached it to the brake hose where it goes between the swingarm and the frame to protect it from rubbing on the frame
Secured it with electrical tape
Attached the magnet sensor supplied with the Innotrace X1 motor
Routed it into the frame
Secured it with zipties
Installed the magnet sensor rubber cover supplied with the frame
Detached the rear brake from the handlebar keeping the tube faced up and placed the frame on side to proceed with cables routing
Attached the brake hose open end to the highest point so it will not leak
Routed the dropper post cable housing supplied with the dropper post PNW PUGET MTB LEVER Puget 2x Lever
Attached the bushing to the cable
Attached the cable housing cap to the cable housing on the dropper post end
Routed the cable though the housing
Routed the motor harness
Attached the fork and handlebar
Put the frame in upright position, attached the brake lever to the handlebar and marked the rear brake cable cut place making sure the brake cable has enough slack inside the frame to make turn in the frame steering head and around the battery upper mount
Removed the brake hose shroud from the brake lever and attached it on the hose
Detached the nut from the brake and attached it on the hose
Attached the olive supplied with the brake kit to the hose
Trimmed the hose
Attached the hose insert supplied with the brake
Detached the original hose end from the brake lever and discarded it
Attached the trimmed hose to the brake lever
TQFreak
180
236
The Bafang m620 wiring harness supplied with Innotrace X1 motor has yellow 3 pins connectors for brakes e-stops but those connectors are incompatible with Magura MT5e brake connectors (2 pins).
You can make them compatible using this method
But I decided to purchase another Bafang m620 harness with Magura MT5e connectors
Unfortunately this cable is shorted than the original Bafang m620 harness and it is too short to fit Dengfu e55 17" frame
So I decided to use these two cable to make one long cable with Magura MT5e connectors
I cut a piece on the motor side from the original harness long enough
Removed part of the main insulation
Cut off the plug from the Bafang m620 MT5e cable
Trimmed the wires with matching colors to the stepped lengths (to prevent growing thickness of the cable and possible shortage)
Stripped and tinned the wires
Attached the harness sleeve to the motor plug exposed wires area to protect the exposed wires and to keep them flexible at the same time
Secured it with heat shrink tubes with adhesive liner
Attached the heat shrink tubes with adhesive liner to the cable and to the wires
Soldered the wires with corrsponding colors and leghts
Fused the heat shrink tubes
TQFreak
180
236
To figure out where to trim the dropper post cable I attached the Kindernay Onesie shifter to the handlebar to the position where it supposed to be, attached the the dropper post with attached dropper post cable, attached the dropper post lever where it supposed to be, maintained proper slack of the dropper post cable inside the frame so it goes in the steering tube and round the battery upper mount without interference and marked the cable trim line
Removed the dropper post and the cable from the cable housing and trimmed the cable housing
Attached the cable to the cable housing
Connected the cable to the dropper post and attached the dropper post to the frame
Attached the lever housing cap to the lever side of the cable
Attached the cable guide
Attached the cable to the lever
eugene8
27
mainland
A sheath for shifter has metal housing inside to prevent abrasion. The hydraulic one is made of plastic. Better find a dedicated shifter sheath for it to live a long happy life ))
BojanZ
46
23
Slovenia
1657
1919
1199
1801
0512
0486
0000
Man, I have to try these paswords, thanks! I also have the same stuff from innotrance as you, unfortunately their responses are very bad and still got no answer from them about this password, even though I emailed them at least three times how to change wheel diameter!! Btw, my stickers on the motor are the same as yours. Have it on E22 frame and set it to 40A max current.
rezystor1990
28
50
Poland
If it's not a problem, you can measure the length:
- the length of the rear brake cable
- the length of the Kindernay cable
- the length of the line to the adjustable seatpost
My frame is still in China :( I currently have a M620 with a seroxat frame, I will be transferring all the equipment to the new frame. If I had the dimensions, I would check if my cables are long enough or do I need to buy new ones.
TQFreak
180
236
I can not measure exact length of those cables - they are already installed on the frame. I can give you rough length when I will have time to measure it but I would not trust those numbers if you are planning to use it to trim your cables.
TQFreak
180
236
OK, I did rough measurements:
Rear brake hose length is about 2000mm
Kindernay each hose length is about 2000mm
Post dropper cable length is about 1670mm
Front brake hose length is about 1000mm
Again, do not trim the hoses and the cables to this lengths, this is rough data I measured without detaching the cables from the frame.
TQFreak
180
236
For the wheels rims I purchased a couple of Nextie [Jungle Fox II] 29" MTB Rim 52mm with 32 holes
The front hub is SRAM 900 Front Hub - 15 x 110mm Boost, 32H, 6-Bolt, Black from eBay
The spokes are custom cut 2mm black SAPIM spokes from eBay
16 spokes 276mm long for front wheel brake side 3 cross pattern
16 spokes 279mm long front wheel non-brake side 3 cross pattern
32 spokes 253mm long for rear wheel Kindernay 32H SWAP Shell both sides 2 cross pattern
Nipples are DT Swiss Brass Nipple 2.0mm
Spokes threat locker is Wheelsmith Mini Spoke Prep, 15ml - Blue
Both tubes are MAXXIS Welterweight Tube 29x2.0-3.0 PV 48mm 0d
Both tires are WTB Ranger 3.0 x 29 TCS Light/Fast Rolling 60tpi Dual DNA SG2 tire
Rim tape is WHISKY - Tubeless Rim Tape - 45 mm Wide, 10 m Long
Reflectors are Labewin
Cleaned the spokes
Applied the threat locker
Lubed the nipples to rim contact surface
Laced the front wheel
Trued the wheel on the fork with a piece of cardboard and a couple of zip ties
Set spokes tension around 100-120 kgf
Cleaned the rim internal surface with alcohol and applies two layers of the rim tape
Cut the hole for the inflation nipple
Attached the tire and the tube
Inflated to around 35 psi to seat the tire bead and dilated to 25 psi
Attached the brake disk
Attached the wheel reflector
Attached the spoke reflector
TQFreak
180
236
And here is the front wheel
Then I laced the rear wheel
Trued it on the bike swingarm with a piece of cardboard and a couple of zip ties
Applied two layers of the rim tape
Attached the Kindernay VII gear hub to the wheel
Attached the brake rotor spacer and the brake rotor
Attached the torque arm with the spacer cup
Attached the cog
Attached the reflectors, attached the tire and the tube, seated the tire bead with pump and deflated the tire (It is not possible to attach this rear wheel to the Dengfu E55 with inflated tire, it needs more room to reach the rear hub slots in the swingarm).
Attached the deflated wheel to the swingarm
Inflated it
This rear wheel maintains about 1 mm gap with the mud cover rubber when it is inflated to 25 psi
Attached the speed sensor magnet
TeoElFeo
185
63
Tallinn
I would say that 1mm gap is far from ideal... Things flex in the rear triangle a bit and mud and some debri can get stuck between the tire and frame. Also if the wheel good out of true it might start rubbing on the sides. Why such a peculiar choice of tyres? To me 29x2.6 seems plenty
TQFreak
180
236
I want to fit the widest tires possible because of they look better and performs better on sand and snow.
Sneak pick. This 52V 3000W Innotrace motor combined with 46T chainring, 14T cog, Kindernay VII at highest gear (2.068 gear ratio) and 29" wheel is able to spin the wheel over 70mph (110kmh) with the throttle
TeoElFeo
185
63
Tallinn
Looks nice! In reality I doubt that 3kw motor will allow you to get to that speed simply due to rolling and air resistance. Nonetheless it will be a very fast bike. Did the 46t chainring come stock with the Innotrace?
I have ordered my frame already and I am planning to go Innotrace with the motor.
TQFreak
180
236
No, the Innotrace went with 44T steel chainring. By the way 44T chainring will interfere with the swingarm if mounted on the internal face of the spider. It looks like 42T chainring is the biggest chainring can be mounted on the internal face of the spider without interfering with the swingarm. The external face of the spider allows to mount 46T chainring maximum without touching the swingarm.
I purchased an aluminum 46T chainring with integrated guard and mounted it on the external face of the spider.
Bengy22
128
87
Bike is looking awesome! Those tires are huge, and the kindernay is looking sweet, loving the huge detailed write up you are going for the build. And looks like you are getting close to doing a test ride which sound be fun to hear about!
TeoElFeo
185
63
Tallinn
Looking at the spider I would say the chainring is meant to be mounted on the external side. How does the chain line look when mounted externally?
Dado
735
497
Bratislava
Tqfreak, you are crazy!
Thanks for excelent photos. Your build must have taken hundreads of hours. Kudos to the stickers. And also to your craftmanship.
Anyway have also Inno and also very bad experience. That company is a joke.
Motor came also not setup as I ordered, X2 display does not work with their controller ( Rico did not want to refund). I had faulty torque sensor from factory! Where is some qc testing? And also faulty throttle. I had to buy programming cable (I think it is intention to ignore your setup then u need to buy programmer also)
I can share a setup, been experimenting a while.
576K
