Neeko DeVinchi
- Thread starter
- #931
T3-5 EC44/ZS56 130-140mm Straight SteererDear Neeko, I bought L size frame..
This is really an updated version. Magura MT5 is the golden standard for MTB-brakes. Even though MT7 exists, majority still uses MT5, because it's reliable and cheaperCan anyone comment on the parts they installed on this e22? Not super into the whole "mountainbike" part of "e-mountainbike" so I can't comment on if they are great parts, or lackluster, or....
Oh I'm aware about their controlers and the coupon code, got the code sent to me via FB message by innotrace, and their only competition (for me as a customer) is their non-special-edition X3. BTW it appears like the post I saw in the Bafang group disappeared...This is really an updated version. Magura MT5 is the golden standard for MTB-brakes. Even though MT7 exists, majority still uses MT5, because it's reliable and cheaperP N W, Fizik, ProTaper, Magura and Shimano are all very well-known brands in MTB. For the main components like fork and shock, they seem to use parts from DVO, which is a young but yet competitive company. I prefer Rockshox over Fox, due to their cheaper prices for replacement parts, but DVO also was on my parts list for my next bike. (read for yourself: A Quick Look at DVO Suspension (Better Than RockShox/Fox/Cane Creek?)) And finally you're getting the powerful X1 controller from Innotrace themselves.. Compared to stock Bafang controller this is a rocket.. Done several thousand kilometers and wasn't disappointed by the reliability!
I also got a coupon code for 1.200€ off. Was primarily meant for our Facebook Group, but I'm allowed to share it here: JJ8Q3FY2
Dear Neeko, many thanks. This is probably the only part whit which I am really not familiar yet. So what do the numbers really mean (44 and 56) and why is there no mention of 28.6 mm (which is the diameter of my steerimg tube)?T3-5 EC44/ZS56 130-140mm Straight Steerer![]()
The headset numbers correlate with the diameter of the headtube diameter both upper and lower. In the E22s case, it uses a 44mm diameter headset for the top & a 56mm diameter headset for the lower.Dear Neeko, many thanks. This is probably the only part whit which I am really not familiar yet. So what do the numbers really mean (44 and 56) and why is there no mention of 28.6 mm (which is the diameter of my steerimg tube)?
Thank you!
The medium E22s should have a headtube length of 120mm'ish. The lower cup should be fully seated into the headtube.My medium (18") E22 frame finally arrived today! First order of business was to swing by my local bike shop and have them press in my Works 2 degree angle headset. Unfortunately the bottom cup fully pressed in has left a 5mm gap. I'm wondering if I F'd up and ordered the wrong headset or if something in the design has changed. This is the one I ordered,
2.0 Degree EC44-ZS56 Angle Headset, Headtube Length:SET 4 120-129mm
If this is indeed the right part should I just run it and call it good?
View attachment 99822 View attachment 99824
Thankfully the headtube measures 120mm exactly. The depth of the Works bottom cup is about 17mm however it's tricky to tell how deep the insertion recess is in the headtube at this point with the cup installed. Is this in fact the right headset then given the headtube length? I'm guessing then this is more then cosmetic and would actually be unsafe to ride this way?The medium E22s should have a headtube length of 120mm'ish. The lower cup should be fully seated into the headtube.
Just to be safe, please measure the headtube yourself @HIDrive. I have noticed discrepancies with certain geometry numbers on my E22 compared to the geometry chart.
Ok, thanks! That means that all forks basically are 28.6 mm on top and bottom if straight, and tapered ones are 39.8 at the bottom?The headset numbers correlate with the diameter of the headtube diameter both upper and lower. In the E22s case, it uses a 44mm diameter headset for the top & a 56mm diameter headset for the lower.
As for the headset correlating with whether it caters for a straight steerer or tapered, usually headsets should verify whether the headset is suitable for straight steerer or tapered steerer.
In the case of Superstar components, they give options on whether you can buy a straight steerer headset or tapered. Just make sure you buy the headset designed for 130-140mm for your large E22 frame![]()
From memory the headset cup depth in the E10 frame is something like 10-12mm (quite shallow compared to most other frame manufactures). The Works headset cup depth is considerably more than a 'standard' headset cup, hence why you've not managed to seat it to the correct depth. You have 2 options:-My medium (18") E22 frame finally arrived today! First order of business was to swing by my local bike shop and have them press in my Works 2 degree angle headset. Unfortunately the bottom cup fully pressed in has left a 5mm gap. I'm wondering if I F'd up and ordered the wrong headset or if something in the design has changed. This is the one I ordered,
A 5 amp charger is fine.So a friend of mine 'lost his s$@t' at me, after discovering that I've been using a 5amp charger to charge my Dengfu batteries![]()
But we are talking about discharging and recharging your battery 1000's of times before rapid charge becomes an issue. In the lifetime of your battery will you recharge it that many times ?Their is an argument that by using the fast charger as the default charger, you degrade the battery quicker.
Thanks for the détailled feedback. Do you think or have experience with swapping the BMS with a more amp capable one ? 30 / 40 amps could be great with X1 controller.A 5 amp charger is fine.
Of course it depends on the cells (and BMS)
You have a 48V 840Wh battery.
840/48= 17.5Ah
The Dengfu battery is 13S5P
17.5/5= 3500mAh cells are used.
Most Dengfu battery's I saw use Samsung 35E cells
Samsung spec sheet says:
For a good cycle life 1 Amp per cell is OK. You have a 5P battery = 5Amps. No problem!
In my own batteries i use a lot of LG MJ1 3500mAh cells.
Their max Charge Current is a bit higher (3400 vs 2000)
And when I am in a hurry I have no problem charging them with 8Amps.
In my E23 I use a 14S5P 21700 with Molicels P42A
Standard charge is 4.2A per cell!!!
I could charge that with a 20Amp charger (If I had one)
Would take less then an hour for a fully charged 1092Wh battery.
The BMS also has a "max charge current".
My Dengfu battery that I bought with my E22 frame had only a "tiny" 20Amp BMS
but even that had 10A Max charge capability.
So I wouldn't worry too much about that.
Worry about the fact that these small BMS used in the E10/22/23 batteries have no balancing function!
Thanks for your detailed response! I had seen this headset reccomended many times in this E22 specific thread so you can imagine my surprise when it wasnt compatible. My build is getting close to complete and I'm exploring my options. I have the headset that was included with the frame kit, I've also thought about making a shim to close the gap in this headset... If there is a 2 degree headset that will work for this frame I'd love some suggestions! I'm still waiting on my rear shock bushings so I have time to order new headset if need be.From memory the headset cup depth in the E10 frame is something like 10-12mm (quite shallow compared to most other frame manufactures). The Works headset cup depth is considerably more than a 'standard' headset cup, hence why you've not managed to seat it to the correct depth. You have 2 options:-
1) get the non-bearing diameter of the cup machined down to slightly below the frame insertion depth.
or
2) get the frame cup location diameter machined slightly deeper to accommodate the 'tall' cup depth.
Option 2 will need to be done professionally to avoid wrecking the carbon frame. Machining the aluminium headset cup, although not ideal, is an easier task with less risk.
I personally wouldn't leave the situation as-is though (shown in your photo) as you run the risk of the cup 'moving about' under load and eventually wrecking the locating diameter in the frame.
Could you please tell me what is your battery configuration and cells used?
Dear Neeko, sorry for bothering you again! Superstar components is unfortunately not shipping to other EU countries, so I found Workscomponents. Can you just double check on this link, I select SET 5 and option WITH reducer for straight fork, will that be ok (especially those numbers of the insertion depth, will it fit)?Dear Neeko, many thanks. This is probably the only part whit which I am really not familiar yet. So what do the numbers really mean (44 and 56) and why is there no mention of 28.6 mm (which is the diameter of my steerimg tube)?
Thank you!
That is the exact same one I ordered and unfortunately the bottom cup is way too thick/tall. I also tried to order a superstar headset but they dont ship to me either so I caved and bought a Wolf Tooth 2 Degree Geoshift which has a 9.5mm insertion depth for the lower cup.Dear Neeko, sorry for bothering you again! Superstar components is unfortunately not shipping to other EU countries, so I found Workscomponents. Can you just double check on this link, I select SET 5 and option WITH reducer for straight fork, will that be ok (especially those numbers of the insertion depth, will it fit)?
2.0 Degree EC44-ZS56 Angle Headset - To Suit Tapered Steerer Tube
Change your bikes geometry to suit you - with our World Cup proven angle headsets you can alter stock geometry, changing the way your bike rides and feels to better match your personal riding style. With years of experience manufacturing Angle Headsets, whether you are just starting out, or the...www.workscomponents.co.uk
Mate, I don't know what to say except a big THANK YOU! For the quality and details levels of your answer. Unfortunately, that might fell off for me, as it seems that I can't order the X1 controller without sending it back to Germany. I m in Australia, so it is not economically relevantMy battery was only 768Wh
and came with a 20A BMS.
Same BMS also exists in a 30A version.
Maybe yours is a 30A version?
Check that first!
If you want to upgrade:
Cables are 14AWG.
They can handle 50+Amps
But there is almost no room to put a decent BMS.
My BMS measures
The only powerful tiny BMS that I know is a Neptune 15 View attachment 100056
It's 5mm longer and 11mm wider. Will be a tight fit!
I went for a 14S5P with 21700 Molicel P42A and a 60Amp BMS.
21Ah 1092Wh
But I had to cut open the frame.
It was very experimental, complicated, non removable
and probably not safe
Would not do this again!!!
Been working on this "removable" case.
3d Printed in PETG
View attachment 100059 View attachment 100060
Can hold 14S4P 21700
With Samsung 50S that would result in 20Ah 1040Wh
Will be using a 60Amp BMS (for Innotrace motor)
Mate, I don't know what to say except a big THANK YOU! For the quality and details levels of your answer. Unfortunately, that might fell off for me, as it seems that I can't order the X1 controller without sending it back to Germany. I m in Australia, so it is not economically relevant. If anyone knows a plan B, happy to hear from you. My only option left would be to install a phase runner from grin externally..that the last option I see...
I was just looking the nex X3 Black Forest on Innotrace site and the photo of geometry also indicates the HEADTUBE length and it is only 120 mm on XL frame. Can anyone somehow check physically on his own frame if this data on Innotrace is ok? It is E22 frame which is Innotrace using?Thanks for your detailed response! I had seen this headset reccomended many times in this E22 specific thread so you can imagine my surprise when it wasnt compatible. My build is getting close to complete and I'm exploring my options. I have the headset that was included with the frame kit, I've also thought about making a shim to close the gap in this headset... If there is a 2 degree headset that will work for this frame I'd love some suggestions! I'm still waiting on my rear shock bushings so I have time to order new headset if need be.
