Levo SL Gen 1 2020 Specialized Levo SL alloy custom build thread
73Steff
98
422
Haslemere Surrey
Thought I’d put up a start to finish build thread on my Levo SL.
For those that don’t know I built up an alloy Levo (three actually for MB Cyclery in Haslemere, have a look at their instagram for pics) in the same Raw brushed alloy finish/process so when the SL was released I knew A. I’d have one and B. It would be an alloy one and finished to match.
Apart from the ‘shiny’ factor in that I think alloy looks better than carbon I also believe (other than maybe a few grams) in reality from a ‘seat of your pants’ point of view the ride on an alloy eBike is near identical to a carbon.
I’ll freely admit, this is not the cheapest or most cost effective way to build a bike.....but it’s different and unique and more importantly I enjoy the process.
Lets start with 2020 Levo SL alloy comp. Take a perfectly good bike and strip it to bear frame??‍♂️
Gary
Old Tartan Bollocks
10,496
10,710
the internet
Do us a favour will ya?
Weigh the stripped frame (both stays and front triangle) before and after paint stripping/polishing.
I've stripped and polished a few frames in my time and am just interested in the weights and weight savings [/nerding]
kombos
253
311
Arizona
This should be interesting.....appreciate you posting the process.
I'm also curious of the paint weight....is the factory finish paint or powder?
ccrdave
1,428
1,125
uk
what are the two holes in the underside of the down tube for?
Damn, without a doubt those are the smokingest EMTB's I have seen to date, baby I like it raw!
MB Cyclery (@mbcyclery) • Instagram photos and videos
Fivetones
898
905
Cheshire
I’m going to guess around 100g but we will see.
helivate
15
Utah USA
Do you have plans to upgrade the fork?
I'm eventually wanting to upgrade to a lyrik I think, but leaning towards a 150 still even though I would love a 160 to slacken the bike a little. (because I've seen several mention it's not recommended to go to 160)
Also thinking of doing a coil for a bit to see how it feels.
Rob Rides EMTB
Administrator
Staff member
6,292
13,854
Surrey, UK
How tall are you? I found it pretty twitchy on climbs with the 150. 160 and it’ll want to loop out way too much for taller riders.
helivate
15
Utah USA
6'1" on a large. So yeah, sticking with 150 sounds like it might be a good idea. Rob, do you know if the flip chip in low is 66deg or is it 65.5?
73Steff
98
422
Haslemere Surrey
Full built spec tbc but will be Full Gas raw.....sticking with air and 150 travel as agree with Rob on handling, I have 160 & coil on other Levo’s so might bang them on just to test, I’m sure Spech will have already done this.
miPbiP
756
806
Surrey Hills.
you're making a really good case for an alloy frame here mate. if you'd consider doing this as a paid service please let us know.
the bash guard on the Levo - did that require extra holes in the frame? (I bash my Levo BB a lot ... but it's carbon).
(& I can get over to Haslemere easy enough, not far away ...).
Blinkie
112
86
aberdeen
Flip chip is 66/66.5 not 66/65.5 as reported in some places
The Specialized technical documents and geometry state 66 / 66.5 head tube angle. 66 degree being the Flipchip on the lower (default) position. I have attached the Levo SL user manual which refers to the flipchip starting page 23. I am unaware of where some testers have acquired this information, but I suspect it may be a typo.
I was told it was default set to the 66 lower setting
Fivetones
898
905
Cheshire
@73Steff while we wait for the paint off weight figures did you get a weight for the stock bike with no pedals? There’s other posts on here that claim a weight I find hard to believe!
helivate
15
Utah USA
19.7kg with my OneUp Composite pedals. (Sorry, too lazy to take them off right now)
And tubes. But I’m installing cushcore, so that probably won’t change much for me.
Fivetones
898
905
Cheshire
Thanks mate. That’s what I thought it would be. What size is that?
Jpzeroday
141
301
Nevada
What was the frame only weight with paint?
Awaiting, Interested in the stripped frame only weight?
Would you happen to know the Carbon frame only weight?
571K
