2023 Giant Reign E+
boarder87
26
17
I have the 2022 with a Float X: Added a volume spacer and running around 210psi for a 75kg rider, still bottoming out here and there but I often huck to flat...
Really? I've Increased pressure to 210psi in my Float X and back on the stock 0.4inch3 volume spacer, also with 75kg. 25% SAG in High has improved pedal strikes a lot. All the last rides with small jumps and in really rough terrain, I had 1cm left on the shock. So enough safety for more. With 190psi and 0.2 inch3 spacer I always used all the travel.
Rando_12345
201
268
France
To be clear, I don't mean that I harshly bottom out, but my sag elastic tends to be all the way down after each ride.
As you said, I arrived at that PSI value in order to stop pedal strikes, I'd happily ride with 200 or maybe 190psi, but can't handle the pedal strikes.
Rando_12345
201
268
France
Dented the rear rim on 3rd ride, do you guys use tyre inserts?
No inserts and no real dents on my ex511 rims. I do get small dents on other rims I use here and there (e.g. my spank and mavic rims are dented to hell, but those have had years of abuse).
However, I run heavy tyres, usually Schwalbe super gravity (~1300g tyres), currently on Continental "enduro" level tyres. I personally do not find maxxis Double Down to be tough enough for my region, despite all the high praise the brand gets.
I run around 1.6bar in the rear, for 75kg.
Donamici
137
169
Ireland
Also dented the rear after a couple of spins. Tried an insert but was such hassle when I had to deal with tear in the tyre that I binned it, and now just run downhill Assegais which are seriously strong.
Rando_12345
201
268
France
Update on this: my local bike shop told me my EX511 is very tired, it is just under 2 years old and has been treated horribly (bike park days here and there and big-ish jumps constantly). That said still no dents, just very hard to true straight.
Wallybean
29
39
Hamilton, Montana
~ 25-30 miles on typical mountain single track with 5-6K' of elevation gain, using level 3 to level 5 assist as needed. Not trying to extend range at all with average assist at level 4. I am 100 kgs riding weight.
boarder87
26
17
5000-6000m elevation gain? Are You serious? With 2 times of fully charging I guess?
emtbeast
235
253
Slovenia
My max was 112km with 2100m of elevation gain with 24% battery remaining or 104km with 2200m of elevation gain and 21% battery remaining. Average Assist mode was between 100% and 150%, stock tires, E+1, me approximately 88kg(gear included).
I also keep statistics for my rides/battery and the 800Wh is as follows:
Average battery consumption is:
32,7Wh/100m elevation gained
with an
Average speed of: 17,6 km/h
Cheers
garypalmer
8
7
Torre-Pacheco
Hello guys, for a weight of 75 kilos do you know what spring to put on the reign. I'm wearing 425lbs and it feels hard, 24% sag. I have bought one of 400lbs.
jeanmarc
402
405
Canada
Any updated reviews for the Giant Reign E+ 1 2023 bike from owners here? I've seen a very good deal new that's tempting me to sell my Specialized Kenevo Gen 1? 🤔
Giant Reign E+… 2022, 2023 & 2024 models are essentially the same bikes. Subtle exceptions are on components and battery that went from 625Wh to 800Wh, everything else pretty much unchanged (frame, geometry, motor…)
Great bike! 👍
jeanmarc
402
405
Canada
Frame issues sorted now then? What about any motor issues as I heard Yamaha motors took a long time to swap if there were warranty issues?
LBS is a dedicated Giant shop, not the largest but significant in sales nevertheless... They were early adopters of e-bike tech (+/- 8 years) they claimed to have swapped one yamaha motor so far.
This is my second Giant e-mtb without issues. I'm not in the UK so water isn't as much an issue here.
529K
