Strava servers has been down all day today so maybe that’s why it haven’t uploaded.Hi Paolo
still nothing has registered on Strava. Any idea???
thanks
Just had a message from strava to say it's a problem their end.my blevo upload took 3 hoursHi
Any one had trouble upload to Strava to day ?
Normally no problem, no settings changed.
@Stumpy do you know why? What is you procedure?I’ve done two commutes today with BLEvo and they’ve both tracked my heart rate from the Apple Watch at 68bpm. I’m pressing start on BLEvo then starting an outdoor ride in the activities app on the watch. Has anyone else successfully fixes this issue? Should I start the Apple Watch activity first?
Cheers
Cheers
Hi @Hitby, yes, I always start an ‘open’ outdoor cycle on the Apple Watch first and BLEvo works well (with smart HR) for me following that.
loving it! won't work with a quad lock mount - use the GLUB or a stretchy silicone one. both have worked fine for me.Hi everyone, has anyone took up on Robs idea of using the Blackview BV6000 for the Blevo app and how have you got along with it.
wow! looks like I already found the answer. thanks @PaoloBLEvoYou have a very old firmware..
If you update it you will be able to change the speed limit..
No problem on old bike model..
If you go in the battery monitor, you can find the total km done..Mission Control has the total odometer reading on the diagnose page but I don't see an equivalent in BLEvo. Am I missing it? Would be nice to see without having to launch MC.
Paolo, if not in BLEvo, is this something you can add to a future release?
My experience with BLEvo smart HR and Apple Watch (4 with cellular paired with a iPhone XS max) is the opposite and all works well 95% (subjective and not empirical) of the time. The other 5% is when BLEvo loses the HR signal from the watch. However, in checking the health app on the iPhone the same data is missing and therefore not it’s a BLEvo issue (IMO).
NB: I’ve not used the latest version of BLEvo but will test when I’m next able to ride.
Out of interest can @Hitby and @Bryan Wells comment on their Apple Watch model and health app data?
Paolo, I found the battery monitor but the odometer is in kilometers even though I have it configured for miles. The temperature is fahrenheit which is correct.If you go in the battery monitor, you can find the total km done..
As far as I know it’s not possible to do a software unlock any more. You’ll need a hardware device like the velociraptor or the planetary gear thingummy.Any new updates on when BLEvo will be able to unlock the 2019 Levos
Ok.. I will fix the convertion in miles... thanksPaolo, I found the battery monitor but the odometer is in kilometers even though I have it configured for miles. The temperature is fahrenheit which is correct.
BLEvo v3.5.1 on Android
You are right.. Until know only hardware or mechanical solutions..As far as I know it’s not possible to do a software unlock any more. You’ll need a hardware device like the velociraptor or the planetary gear thingummy.
What about for iOS?
It seems to connect much faster with the bike now.I have just released the new version 3.5.2 of BLEvo for Android ..
Here are the news:
- Optimized Bluetooth connection
- Added description with BLEvo statistics uploading to Strava
- MAPBOX map type added
- Added possibilities to overlay images to the map from the CSV
- Now if the SpeedMultiplier is greater than 1, it displays the maximum speed you get
- Added the choice of color and the size of the arrow on the map
- Added the choice of zoom step on the map
- Bugfix: restore service values when not in Smart Power
- Fixed Label Biker / Battery in the tour map (now it's wh biker / wh tot)
- Now set the GPS speed only if the bike is not connected or is off (not 2019). Avoid the calculation of ascents in the gondola
- Now if the CSV file is small, the graphic in the bike monitor is loaded in high resolution
- Added configuration to remove the initial BLEvo message
- Added information on the KMs made and the status of the battery in the bike monitor
- Updated Andromap style
- Added Strava configuration in the BLEvo configuration menu
- Added Good GPS counter in the CSV
- Now on the increase of manual assistance, the steps are not broken, that is, if it is +5 a multiple of 5 always remains
Update from Google Play and let me know if you have problems.
Good lap with BLEvo ..
https://play.google.com/store/apps/details?id=com.dopa.android.blevo&hl=it
