Shimano EP8 stops working while riding - no fault in log?
hctagalong
14
Minnesota
Well how’s it going lads any joy in recent weeks? I run a guiding business and now have 2 in the fleet with this problem 🙈
I've finally connected with a helpful Canyon technical support rep (I'm in the US) and he has been working with Shimano via the warranty claim process. Shimano thinks the problem is the battery+wiring harness (the wire that runs direct from the drive unit to the battery) and are sending me replacements under warranty.
To be honest, I'm skeptical that this is the culprit, but what do I know -- I'm a rookie with regard to eMTBs. Further, I've already tested with a different battery and it was fine for a few rides then the dreaded power cut happened. I've reviewed my ride data and have the following observations:
  • Problem always happens when the temp is 70+ (Fahrenheit); relative humidity doesn't seem to matter
  • Never has cut out at the beginning of a ride; always 1+ hr into the ride. I usually start my rides at 100% battery therefore the battery consumption is around +/- 60% when it happens (not the same each time and one time the consumption was only around 45%; an outlier but was fairly warm that day)
  • Only occurs at trails and outings when I'm riding a bit more "spirited" (constant motion, pushing the pace, rougher terrain). Ride a little lighter pace with some stops along the way, no power cut.
Given the above this seems like a thermal problem to me but again, Shimano believes it's a battery+wiring harness. I haven't received those yet but should early this week. I'll get them on straight away and try again. The challenge is that it's getting cooler where I live now that summer is winding down and I've not experienced a problem, yet, with cooler temps (I got the bike September 2023 and didn't have any problems until June 2024). For reference, I now have just over 500 miles on it.
I'll let you know what I find after I get a few rides in with the new wiring harness and battery.
Well....bummer. New battery is not the answer. Another ride (using the alternate battery) and unfortunately additional power cut-outs. :( Again, no faults in the drive unit logs. And, like the other events, it doesn't occur until later in a ride (60%+ of the battery consumed). Only guess I have left is that it's a thermal-related problem.
At this point I have nothing left to try except keep working the warranty process (which has its own challenges that I'm learning about).
this is the best narrowing down of this problem I’ve seen on the internet 🙏
Ok so, I have one bike (Husqvarna mc4 23) , I believe it’s likely the wiring harness one really brutal day of dh runs on the “sram test track” in mijas Spain (next bike could be thermal 🤷🏼‍♂️) started out with a silent bike but could hear the battery slowly rattle its loose inside the carbon frame and problems started but manageable also aggravated by the hot Spanish summer 40+ Celsius, Every man, beast and machine is suffering lol
The Other bike a husky mc2 with ep6 motor doing the same when it gets warm cuts of sometimes even on smooth roads, no error log but definitely heat related. I’m noticing across the bikes that if it gets hot enough that it won’t turn back on any given ride from then on it cuts out after roughly 50% battery usage or a good hours worth of abuse, but I haven’t found any info on heat sensors or anything like that yet.
@hctagalong if you ever escaped the winter to southern Europe you deserve a complementary emtb tour some day for that quality of detail in your e-bike experience 👍
Borbea
46
28
Sweden
I had this on my Husky. It was bad connection between the battery and connection plate in bottom of battery compartment.
Remove the battery unscrew the plate (battery connection) in bottom of battery compartment. Spray some WD40 and dry. Assemble all back.
Also check the power button.
hctagalong
14
Minnesota
Minor update:
I received the warrantied wiring harness and battery from Shimano (via Canyon) and haven't had a cutout since replacing both. While I'm near positive that the battery wasn't the problem (recall that I had tried a second one from the original and still had cutouts -- I'm skeptical that 2 batteries would be defective) perhaps it actually was the wiring harness 🤷‍♂️.
When I replaced the wiring harness, there was no apparent damage to the original one; no cuts, kinks or worn through casing. Nothing of note. Both ends of the connection look normal as well -- on the Spectral:ON the wiring harness is simply a cable that connects to the drive unit and battery directly with no fixed plate/retainer/etc.
Is my saga over? I'm hopeful but not totally convinced. I have ~ 100miles on the new battery+wiring harness but none of that was in hot weather or as spirited riding as when I've experienced the cutouts. Now that temps are falling in my area, I doubt I'll see this again until next season if I do at all.
I appreciate the support and suggestions. Should any of you have cutouts, I feel for you and hope you get it sorted out quickly. Shimano is confident that this will address it for me, time will tell.
9,886
I had an intermittent power loss problem.
Long story short, it turned out that when a new battery was fitted under warranty, they pinched one of the cables going to the display. That was all it took. There was no external sign of damage. The cable cost £7, but getting to it was a problem (on a Focus Jam2 and not designed to come out as a matter of course) and therefore expensive. thankfully it was still under warranty.
Trickfox
Figured I'd add my story as another data point. Bought a 2023 Canyon Spectral:On with EP801 & 720 battery in May. Experienced the random cutoff issue starting in June. Did a warranty claim with Canyon through an LBS. At first they were going to send a new harness to the LBS, then decided they thought it was the motor. Shimano provided a replacement motor. About a month on the new motor, and the issue started again.
I've mostly ridden in hot weather, so my first assumption was heat. But I've had 100F rides with no issue, and 80F rides with cutouts in the first 10 minutes, before the motor could have gotten too hot.
I usually experience only one or two cutouts over the course of a 15 mile, 2 hour ride. Sometimes I can do a big ride with zero cutouts, and other times I've gotten three on an 8 mile loop.
It also doesn't seem to be related to battery level, vibrations or big hits.
It has never happened while pedaling, only when coasting.
My LBS did say they've heard of the issue and have heard it's a problem with Shimano motors paired to non-Shimano brand batteries. Curious if anyone with a Shimano battery has had the problem.
It's such a mild annoyance, and seems to not have a known fix, so I'm putting off starting another claim. Will keep my eyes on this thread, hoping a solution is found some day.
ramirez.jon
Azusa ca
Did you guys get any error codes?
My Santa Cruz heckler is having this same issue and splaying E020!
. LBS had had my bike for 3 weeks now and are waiting for a new wiring harness to see if that is the issue.
hctagalong
14
Minnesota
Nope. In my case there were no associated error codes. If the E020 was related to your issues, consider yourself lucky to at least have something to dig into with regard to triage.
In my case, I received a new wiring harness and battery. It was fine for a little while but then started acting up again for no particular reason that I'm aware of (and no, no error codes, either). Since then, Canyon Spectral:ON owners have been under a "stop ride" notice related to some battery problems. Further, I'm in a cold climate in the US so my outdoor riding season is paused anyhow. Because of the stop ride, you probably won't see too many Canyon owners posting about problems.
Hopefully your LBS will get this sorted out for you! Personally I think this is a big annoyance and would be thrilled to find a solution. To date, I haven't heard of one. Good luck to you!
Trickfox
No error codes for me either.
I can add another follow up. Per my last post, LBS initially replaced the motor, but I started experiencing the cutout issue again shortly after. Then one day the bike just would not turn back on at all! This time they said it needed a new harness, and I waited nearly 2 months for one because Shimano said it was on backorder. New harness installed, and I have not had a cutout since, which has been about two months.
Trickfox
Another follow up, a couple of months with the new harness and I've started getting the cutouts again :( I have two friends with the same bike experiencing cutouts as well. We're starting to think it's sensor related, as it only happens when we stop pedaling, and it might even be related to slight back pedaling.
hctagalong
14
Minnesota
Dang -- bummer to hear that. Frustrating. I've read elsewhere that the problem could be related to the speed sensor. In that thread, it was asserted that there was a small cut in the wire leading to it. When it got wet, that caused problems.
Prior to my getting rid of the bike, I continued to experience this problem even after battery replacements (yes, multiple) and wiring harness replacement. The problem happened in warm weather and cold weather, dry and wet conditions. The best advice I had seen was to verify connections for every wire and inspect for kinks/bends/cuts along all wires. I didn't find anything in my case that was obvious, hopefully you'll find something actionable.
The only common thing I had observed was that the cutouts usually didn't happen until the battery was at 60% or less (meaning that it rarely, if ever, occurred at the beginning of a ride) and the ruggedness of the trail seemed to have played a factor (which could be coincidence where all but 1 ride with cutouts was on a very rocky/rooty trail vs. only 1 ride with cutouts on a fast/smooth/flowy trail). While I doubt the trail had anything to do with it, that could have had something to do with cadence as you suggested where there was more start/stop + back pedaling. Ultimately, I gave up and ditched the bike (it was a Canyon Spectral:ON) because of the cutout issues and because of the ongoing battery recall saga. Hope you find a solution.
Trickfox
One more piece of data, a buddy's Spectral:ON died on the trail one day (would not turn back on), just like mine. At home he pulled the motor cover and unplugged everything, plugged it back in and it booted up after that. Took it to LBS who called Shimano who said to just do a reset. His bike's been working since, but he does get the random cutouts still. But if it ever dies on me miles from the car, at least now I know I can try disconnecting things at the motor to see if it'll come back alive.
Canyon is supposed to ship new batteries in March. Once I get that, I'll reach out to them for the third time to see if they have any more insight into this issue. As common as it seems, surely they should have figured it out by now.
570K
