Levo Gen 3 New brakes... What does everyone run?
Dave_B
1,470
1,601
Newquay
I didn’t use braided lines. Can’t see the point.
The frame has tubes in it for routing the hose, you should be able to just push the new hose through. But yes, connecting old to new should do the job nicely.
Koban
86
134
Using on my Canyon Torque On the Magura MT7 Raceline with SHIMANO XTR M9120 levers and Magura MDR-P 203mm rotors. This combination is working for me.
On the Canyon Spectral ON I use the SHIMANO XTR M9120 brakes. With 203mm XTR rotors. Also working fine. Only thing that I somehow cracked my pistons several times. So I'm converting this now to Magura MT7 Raceline calipers and MDR-P 203mm rotors. with the SHIMANO XTR levers
The choice for brakes etc will be for everyone different. Depends on your own preferences and your own experiences.
Ou812
834
590
Inverness
Those running the Hope V4s, did you go with the branded lines? And did you just cut the factory cables at the caliper, attach the new cable, and feed it through?
I got a smoking deal on my T4V4s as they were the last set in the shop, if I would have went with the braided hose it would have been closer to retail price as he would have had to order them. I’ve dealt with braided hoses though and trimming them sucks so I probably wouldn’t have chose them anyway.
You don’t have to attach the hoses together, there’s an internal sleeve that the hose slides through. You just push it in and it comes out at the top.
rzr
414
264
bcn
Never SRAM, Saint or other new Shimano 4-pot.
Hopes aren't too strong (unless something changed recently?)
Bubbel
I would always ride Shimano 4 pistons again
XT or XTR
A dream with the TRP R1 disc
Ride 2d@y
93
115
Mexico
Just had Lewis LH brakes installed on my Levo SL last week - no lack of stopping power is all I can say so far!
Ride 2d@y
93
115
Mexico
I have some Ali Express Pro E4 brakes which are very similar also tired their ZRace levers with Magura calipers
Yes - but are they as beautiful as the Lewis? Plus I had a dealer source and install the brakes for only about $525 USD
Type1
82
49
Uk
Very happy with the Hayes A4 Dominions I've recently installed. Nicely designed bleed process, exactly the same as a car caliper.
Teoslav
17
25
Zagreb, Croatia
So I am 25 years old. My first real MTB was a Kona process 167 with sram guide RSC, next bike was with the shimano saints. I rode those 2 brakes for about 6 years. Then I became a magura fanboy mostly because of their price. The last bike I got was fully custom and I bit the bullet and got the Hope 4 V4s. I can not tell you how good those are. The modulation and the powaah, my god. I got them paired with some 2.3mm thick brake discs and some braided cables. I really can not stress enough how good the brakes feel. Even when at the end of the run. Best brakes I have ever tried.
SP5657
23
Kent
I swapped from Magura MT-7's to Hope Tech 4 EV 4's with Hope rotors, I personally prefer the Hope set, but the MT7 is still a very good brake set (I have them for sale if you are looking for 2nd hand)
Theo43
7
10
West Marin, CA
I'm running the new Slab Calipers from Cascade Components mixed with XT Levers and Absolute Black Graphene pads...and Intend 2.25 203 rotors.
Odd combo but good....very powerful with good modulation. Hard AF to bleed tho.
Ou812
834
590
Inverness
I was interested in giving those a try at one point but cascade closed their UK store. You can’t order from the EU store since the UK left the EU union so it has to come from the US store, it ends up costing about $200 more after shipping/custom duties/VAT is added.
tjl5709
26
39
Michigan
I'm late to this, sorry, but if someone searches its something they may want to try if you want to save some coin.
If you are running SRAM Codes, look up on utube "how to make your sram brakes not suck".
When new, my Levo's brakes felt soft and mushy. Found this video.
Its a different way to do adjust them. It worked very well for me. It changed the feel completly.
Spent my upgrade money on a oneup dropper.........
mustclime
514
402
New Jerzy
My buddies Rail had sram guides that were really weak. He bought some Code stealth ultimate levers and just replaced the levers for a little over $200 bucks. Brakes are awesome now.
faberle
90
85
France Haute Savoie
I went for Trickstuff Maxima (I was lucky to meet a rider who had them and was nice enough to let me try them). Zero regret despite the price. A very significant improvement versus any of the good brakes I had (Saint, , MT7, code RSC, stealth). Very high and consistent power, buttery smooth and confortable lever, great modulation, super clean cockpit.
travelinscout
35
9
Tucson
I'm obsessed about brakes. During my 30+ years biker carrier I've tried virtually all brakes from big and small brands. I was never happy with any OEM set. Around 2010 I started to build my own "custom" brakes, which is now very popular.
My first "custom" set consisted of: Avid Juicy Seven master cylinder plus Straitline levers and Code calipers connected with Goodridge lines. It not only looked good but also worked great!
That's the history...
My Levo came with Codes which slowed me down but I was not happy. I didn't want to go the "custom" route again (I got lazy with age) so I decided to go crazy and got Trickstuff Direttissima complemented by Galfer Shark rotors (223/203) and Galfer G1652 purple emtb specific brake pads.
The stopping power is remarkable, providing a sense of control and safety that enhances every ride. The build quality is impeccable, reflecting the craftsmanship I appreciate as a perfectionist. Setting up the brakes was a straightforward process, and their durability gives me confidence that they can withstand the demanding conditions of my favorite trails.
What truly sets these brakes apart is their consistent performance across diverse terrains. I hate wandering braking point or different lever stroke of some brakes during long downhill sessions.
Trickstuff Direttissima has been a game-changer for me. They embody the precision, reliability, and performance I seek in brakes.
Can you share where you purchased these?
travelinscout
35
9
Tucson
I run Shimano XTR with Hope rotors. This gives me the stopping power with a bit more modulation. I used to run the entire Hope package but felt like the Hope E4s required a bit more grip strength. Love the adjustability of the Hopes though. Haven’t tried their latest version of the brake yet. I personally can’t stand any of the SRAM brake products. They are heavy, seem to always make noise, and are a pain in the butt to work on.
Are you running the standard XTR setup with the Hope floating rotors or which ones? I am trying to find a better braking solution for my Strive ON. Thanks!
Heated
26
12
new zealand
I have maven's on my other Ebike, They are immense, nothing else compares.... I know that sounds rubbish but I've had A4's, Hope t4v4, saints, code rsc etc...
Nothing compares to the new mavens.... probably other than the trickstuff
The xt's I have rattle and rub(not using finned pads) with 220 rotors.... need that size to make up for power.(see my other posts)
travelinscout
35
9
Tucson
Do you mean the Maven Silver?
Sram Maven Silver disc brake set 2024 LordGun online bike store
Do you know if they will work with the Hope floating rotors?
BikeBert
109
669
Croatia
I got my Direttissima brakes from Bike24. Finding them in stock requires both luck and patience. Another store where they occasionally appear is R2-Bike (https://www.r2-bike.com/). Yet another place is the Liteville store in Torbole by Lake Garda. You can follow their Facebook page (Liteville Testzentrum Torbole / Lago di Garda | Nago), where they often announce when they receive a new batch of Trickstuff brakes.
In short, it's tricky to get Trickstuff brakes, but they're totally worth the effort.
Ou812
834
590
Inverness
Bikecomponents.de is the official supplier of TrickStuff now, they show the Direttissima, Maxima and Piccolla in stock. I tried to order some a few years back when Trickstuff was the only place that sold them, I was originally told 6 months but that turned into 18 months so I canceled the order. They’ve gotten a lot better since being bought out by DT Swiss and actually have stock now.
566K
