Hi all,
Looking at replacing the Code R on my Levo and to be honest Im not sure what to go for.
The reason for wanting to replce the Codes is down to the fact they seem to be high maintenance, requiring a bleed after less then 100 miles and worn through a set of rear pads already. I have to keep pumping them to get a decent feel which isn't always ideal when barreling down a trail.
In the past I have run Magura MT7 which were good but constantly rubbed, Shimano XT no issues, Saints really good and older stuff like hayes 9, hope mini etc.
I could easily settle on another set of saints but after reading some more recent reviews it seems they have been caught up in power terms by the like of hope, hayes and formula.
Quite like the look of Hope Tech 4 v4 but seem very expensive
The Hayes Dominion A4 sound good too but I've heard its a faff to get the larger diameter hose through the frame.
Apparently the Formula Cura are meant to be good but not seen many reviews.
Then there is the Lewis brake that has recently popped up, apparently super powerful but unknown reliability?
Im a heavier rider so need all the power I can get to be honest. Used to like the on/off feel of previous shimano brakes but could get past that if the new brakes are good.
What are you guys running and how do they compare to the Code R?
Am I better off sticking to saints or should I consider one of the above at the extra expense?
