Dazzling1984
Are there any threads somewhere on here with any tutorials on how to replace the Kenevo gear cable? A video link would be amazing!!!
Sorry yes, i mean the outer =/=/=/ not so easy!?The internal is easy, just remove the current one and replace with a new one
Unless you mean the Outer cable (black one)
Thanks Dax, but Im not really that confident i can do that kinda thing atm. Id love to see a tutorial of someone doing it first, if there is one floating around on the ethernet?Isn’t it just a case of drop the motor and battery, and feed it through? Just be careful of the internal wiring when you drop the motor out.
Cool MagisterBibendi, nice1, so is this one of those little things that you screw into both the cables connect them together n pull one through? isnt it really for seatposts?I have successfully used Rockshox Reverb Barb Connector in other bikes to connect the old (still in place in the bike) outer cable to new one. Then just pull the old outer cable out, which pulls the new cable to its correct place, voilà.
EEEEEEEEEEEEEEEEEEEEKKKKkkkkKkkKKkk...That would be fun XD Drop probably being the key word with my current capabilities...=/You may not need to drop the motor, but if its anything like my SL Comp then the cable will get stuck when you try to remove it
I currently have the outer cable still there until I get around to dropping the motor to remove it
This was the way when I change the hose.I have successfully used Rockshox Reverb Barb Connector in other bikes to connect the old (still in place in the bike) outer cable to new one. Then just pull the old outer cable out, which pulls the new cable to its correct place, voilà.
Exactly. I don’t actually know how it is intended to be used in its original application with the Reverb. But works like a charm with any cable outer housings. If I recall right the other end of the barb connector at least was reverse threaded, something to keep in mind.Cool MagisterBibendi, nice1, so is this one of those little things that you screw into both the cables connect them together n pull one through? isnt it really for seatposts?
Excellent, many thanks for that, much appreciated, Sir =)Exactly. I don’t actually know how it is intended to be used in its original application with the Reverb. But works like a charm with any cable outer housings. If I recall right the other end of the barb connector at least was reverse threaded, something to keep in mind.
