Dengfu / Bafang battery charger - which one?
Rob Rides EMTB
Administrator
Staff member
6,227
13,549
Surrey, UK
Hi,
Dengfu sent me a new battery for the new bike build but no charger (usually they come with them but my build is for a video!)
Any idea which charger is compatible or one that I can purchase?
thanks
Rob
Mabman
1,093
1,793
Oregon USA
Any 48v charger that has this type 5.5 /2.1mm plug will work. There are no special communications to consider.
Personally I use a Grin Satiator charger that will charge up to 8A.
Rob Rides EMTB
Administrator
Staff member
6,227
13,549
Surrey, UK
Great thank you!
So this should be good?
YZPOWER 54.6V 4A Battery Charger for 48V Lithium Battery Pack Scooter Electric Bike Power Wheelchair 5.5mm*2.1mm Connector
djol
38
17
Tasmania, Australia
While we’re talking battery chargers…
I assume it would be unwise to use my existing fancy Luna 52V Advanced Charger (man I love that charger for my BBSHD bike) on the 48V Bafang/Dengfu battery when it arrives with the E10?
Mabman
1,093
1,793
Oregon USA
If you had a 52v battery it would work just fine:giggle:
Question is will the M500/600's run on 52v? Sure wakes up the G510....not that it really needs it:devilish: But the E10 and E22 frames use the same battery case.
Waynemarlow
1,076
876
Bucks
The M600 works fine without any mods, even a fully charged battery at 58.4volts does’nt seem to give ERR codes. I quite like running mine on the higher voltage as it brings the top cadence up a bit.
The downside is you cannot get minimum support to enable riding with analogue riders.
545K
