Bosch Domination?
chamaruco
Inactive Member
Dec 28, 2020
393
329
Arezzo
i'm so emotive :ROFLMAO:..when i'm under pressure, stressed climbing on a rock avoiding to fall down, now i mischange the dropper with the gears...can imagine what can i mess up with this
Gary
Old Tartan Bollocks
10,496
10,705
the internet
How much of the overall result is down to hill climbing ?
seems you need to be French to win too…
DH is more about bike kinematic and rider ability at the discipline of DH. Less about which motor. DH it’s a lump of weight. Ok the weight distribution will have some effect with designs that place the battery lower. Although most mainstream designs try to achieve this now.
if it’s just about using the motor to get in more scored DH runs in a day then those best at DH will do best.
DH pedalling prowess is probably why you still see Tracy and Nico on the stands.
id also guess the top riders have been sniffled by top Ebike manufacturers and that the Bosch motor element is more coincidence than outright performance gain. Reliability is key; if your motor breaks its game over pedalling a lump of 24kg iron around the Alps. on this note I’m amazed how Lapierre seem to build bikes for competing that don’t fall apart in the downhill section.
if you get rid of the power stage just get rid of the motor and call it an EWS …
It's not DH though.
It's Enduro. (a bit like multi stage DH but with quite a lot of shite pedally sections, some even uphill)
The power stage is ALL uphill and motor choice could easily mean as much as 10+ seconds difference for the rider.
10seconds in a closely fought enduro is massive
The power stage results are only fair between riders using the same motors
jooles
158
126
South Wales
It's not DH though.
Mind Enduro is starting to look very DH on some courses. Agree ref motors. Also longer chainstays
20,840
Is there actually a chart/list/pdf anwhere which actually shows which riders are on which bikes ? I can't find anything.
The GLP2 is obviously a great mix of motor/bike/weight and in the right hands is a capable bike (which doesn't seem to fall apart in completions for some reason).
Someone could argue that the lighter SL or Rise bikes could do well because of their lower weight making up for less power - but does this just show that if you have a capable rider, that's less of an issue ? Or that the courses are laid out more to take advantage of more power ? Reading comments from people who've ridden the power stages, they're not just straight uphill, they're a challenge in their own right.
Gary
Old Tartan Bollocks
10,496
10,705
the internet
Mountains do look similar. Yes.
Any Uphill section momentum alone can't carry you past does not belong in a DH track.
Certain EWS stages have 30s+ of uphill in them
@Zimmerframe Pretty much every EWS rider has an instagram account. And they all tend to promote the bikes they're on fairly regularly
IIRC when EMBN or similar did a feature on the EWS-E last year, the lighter riders had a significant advantage on the uphills unsurprisingly. They also mentioned that most riders where not using the top power mode as you had more control in EMTB Mode/Trail etc.
If you look at the riders at the top I think its more about whose the most experienced on EMTB's and a good rider.
Also the Lapierre riders are riding lighter bikes with external Bosch 500wh batteries.
So if you look at Nico he riding the lightest bike ( which he himself designed for E-Bike racing), with the most powerful motor, and is also sub 70kg - throw in the experience he has and its a surprise if anyone else wins.
I think its a valid enough series, I dont think the motor plays too much a part in splitting the field, but I also think it does enough to make the choice of bike a factor in the results.
It would be interesting to see someone on an Orbea Rise or Rotwild R375 tackle the uphill stages - I reckon they have enough power not to be left behind, but the significantly lighter weight would really help in line choice.
jooles
158
126
South Wales
Along with long chain stays. The GLP2 has shorter CS hence why probably less uphill traction but more DH pop and faster cornering.
I‘d like to know what strength loctite was used by Lapierre mechanics to keep the rear axles in :)
Hamina
500
396
FIN
I would like to see the amount of used Wh of battery as variable. It would force motors to be more energy efficient and riders balance on using electricity. This same could apply on Strave ebike segments.
It should though be so that it wouldn't be possible to beat ebikes with normal MTB and 0wh battery usage = more difficult tracks.
jooles
158
126
South Wales
Given eMtb take/adoption has exploded; in 40 years taking part in “extreme” sports have never witnessed the sheer growth of a sport. Especially one in which you need to invest an average of (guessing) £6,500.
Ergo it seems natural to get people competing on such bikes, to further promote the genre, drive development and contunye strong growth in sales.
However one could argue they haven’t really found the best way to ‘compete‘ on eBikes. These aren’t MX bikes that have a range of 100 miles flat out across varied terrain, there aren’t DH rigs that are basically shuttle up and blast down. They aren’t a blend of XC and DH, aka Enduro. Ebikes kind of fall between the gaps. Hence why only a tiny percentage of scoring marks on the EWS-E was allocated to actually using the battery. Well from what I could see.
Perhaps a more adventure related completion environment would better suit. Thoughts (from someone totally non versed in these things) based on the strengths of an Ebike, ie being able to go places and distances one would struggle to on a non Ebike.
- Based on conserving power over distance (Wh suggestio above)
- Navigation; run like orienteering
- Timed sections that are less DH and more “aggressive XC”
- Team work, maybe kind of tagging like a relay
- including sections you would have to push up on a pedal bike
- Distances that you would struggle to cover on a pedal bike eg over 100km a day.
- Maybe something like the paragliding equivalent of the X Alps comps
Steve Jones did an epic Alps ride/ comp. That kind of format seems good. Something you’d never consider on a pedal bike unless a total pain nutter.
To me they have taken an existing format designed for pedal bikes and tried to squeeze ebikes in.
Just my thoughts perhaps another thread is emerging. Maybe we cli.d get together and design something ?!
Aug 31, 2020
25
23
Sospel
I think it depends on the terrain. Motor difference and rider weight make a big difference where it's just uber steep, but when it is slightly less steep but more technical (rock steps and tight technical switchbacks), there is more emphasis on rider technical skill and line choice than pure uphill speed.
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
This is only an issue if you race though, isn't it? For the rest of us there is still that balance of power / torque / battery usage. And there are many of us who don't use maximum settings.
smtkelly
204
184
ldn
Interesting. All I can think of is the parallel to motor sports where power won races but doesn't necessary equal a fun car to drive. There was also a hell of a lot of cheating going on.. but that's just racing.
The benefit to regular emtb users is trickle down effect from manufacturers innovation to do each other over. As an end user i'd pick fun over performance.
My bets for EWS-E innovations;
Traction control + intelligent over run
Some kind of launch control for going up really steep sections (combining walk mode's minimum speed, max torque and over run)
Battery as structure - cars and motor cycles have been doing this for years now
Integration of wireless shifting controlled by the motor
Less fluff like fancy displays and other such things that get easy broken
Uniform bolt head sizing
Gary
Old Tartan Bollocks
10,496
10,705
the internet
Most of your ideas would hinder a technically proficient rider not help them
Also. You guys do realise EWS-E is just a mickey mouse race attended by 40-50 folk? and apart from the few ex pro riders who compete in them no one's even heard of most of them.
The motors have to be stock units regulated by EU restrictions so no innovation is going to be made just to suit a miniscule amount of folk for one stupid climbing stage in a few races a year.
Pivot
668
1,088
New Forest, England
I for one am delighted that Bosch is starting the eMTB arms-race. It is a high profit margin business, competitors will have to respond and it will drive innovation.
If ebikes are regulated on max Watt and assisted speed, there is an opportunity in other areas, e.g. power delivery, or get rid of the derailleur from the last millennium. It might be fine on the road… off road it gets ripped off.
smtkelly
204
184
ldn
Nah most of this is software, either the manufacturers will do it or some 3rd party will edit the software for maximum performance.
I could see walk mode beign used on a hill climb as anti-stall (tbh I'm surprised no ones not ones been caught with their walk mode set to do 25kph)
Bosch are already doing that overrun thing on a half pedal, would make logical sense that combine it with traction sensing and maximum torque.
The shifting has already been talked about where the motor picks the moment to shift so not to snap chains my thoughts are what else could that be used for? Shifting without pedalling?
EWS-E is micky mouse now but most sports start off like that
Jimbo Vills
805
1,429
Kent
Traction off road will never work on an eMTB. Specially on a lightweight (or bike that’s better the lighter it is) bike with hardly any power on varied terrain…. cost v weight v actual performance gain and it’s a non starter imo.
I see the benefit on a 200+bhp superbike that’s trying to spit you off. On consistent tarmac.
But even then it’s taken years for it to actually work well enough for it not to be a hindrance for most….
All id ever want to see from any form of e bike racing / development is lighter bikes, with more efficient reliable motors and larger capacity lighter batteries….
The rest ain’t broken so don’t need fixing imo
20,840
Will we see other manufacturers start to pull out of motor production in a similar scenario to Nokia, Blackberry, Palm etc.
Generally, no. It's a growth segment with more coming every day. Though some obviously decide it's not part of where they want to be business wise, like continental who dropped out.
559K
