Wallybean
Looking for recommendations for which bike computer works best with the Giant Reign e+.
Thanks in advance for your thoughts!
I paired my Garmin Edge 130plus successfully using Ebike Field (available on Connect IQ store). It worked well enough, giving me battery percentage and selected power level however my Edge 130plus stopped connecting to satellites a few months ago so has now become useless as a GPS so I'd hesitate to recommend it. The font used for the ebike data fields was quite small as well (and not adjustable AFAIK) which is a bit of a pain if you need reading glasses (possibly not an issue for you).Looking for recommendations for which bike computer works best with the Giant Reign e+.
Apologize for my ignorance.Successful Garmin Edge 530 user here on a 2021 Stance.
Were I to do it again I'd go for the touch screen for easier setup and on the fly route planning.
If you are out on a ride you can use the map to find a place you want to go to, make that your destination and the Garmin will guide you there.Apologize for my ignorance.
Garmins allow for on the fly route planning? I thought it was necessary to import a route into a Garmin, from a phone or a laptop?
Thanks!If you are out on a ride you can use the map to find a place you want to go to, make that your destination and the Garmin will guide you there.
It's a PITA without a touchscreen with pinch to zoom and touching the point on the map.
Hi Wally, what are you planning to do with the computer. The Giant app has rudimentary functions and tuning for the bike via Bluetooth (assuming its similar to my Trance E+ 2). Nothing compares to a GreyP but wondered what functions you're after?? ALooking for recommendations for which bike computer works best with the Giant Reign e+.
Edge 830 paired with Orbea Gain, Orbea Rise and Spec. Turbo Levo via the E bike field.Looking for recommendations for which bike computer works best with the Giant Reign e+.
You can download or convert pretty much any Openstreetmap based map to Garmin Edge navigators. That's the main reason I use Garmin instead of Wahoo. Never heard of TwoNav Trail-2 bike, sounds interesting , I'll take a look.It's worth looking at the TwoNav/Ordnance Survey Trail-2 Bike.
It's also WAY better value than the equivalent Garmin, and if you're in the UK or Europe the map detail is far, far better than Garmin.
You can put OS maps on one too, but just that upgrade alone costs as much as the whole Nav.You can download or convert pretty much any Openstreetmap based map to Garmin Edge navigators. That's the main reason I use Garmin instead of Wahoo. Never hear of TwoNav Trail-2 bike, sounds interesting , I'll take a look.
I'm not really into analysing metrics of a ride - just want to see where the next junction is on the offroad byway, how far I've ridden. And I do like OS Maps. I know I could put my phone on the handlebar (I have the OS app, which I like), but I'm wanting something a little smaller, more robust. Three years OS subs, 6 free 1:25000 tiles and free 1:50000 UK appeals.It's worth looking at the TwoNav/Ordnance Survey Trail-2 Bike.
It displays and records ride routes, HR, Cadence, Power etc etc.
It can store loads of routes, and you can send routes to it from a phone app. It can be set to automatically upload your rides to Strava etc if you want as well.
You can send a beacon of your location and there's an emergency function too if you get in bother.
It's also WAY better value than the equivalent Garmin, and if you're in the UK or Europe the map detail is far, far better than Garmin. I'm not sure how good it would be in the US or Aus though.
It sounds like it'll do exactly what you want.I'm not really into analysing metrics of a ride - just want to see where the next junction is on the offroad byway, how far I've ridden. And I do like OS Maps. I know I could put my phone on the handlebar (I have the OS app, which I like), but I'm wanting something a little smaller, more robust. Three years OS subs, 6 free 1:25000 tiles and free 1:50000 UK appeals.
Is the OS Trail 2 what I need? Or is it an old gen clunk-fest that has rightly been put to pasture? Thanks
Garmin connect to the reign for battery life and power mode integration. Really handy.Looking for recommendations for which bike computer works best with the Giant Reign e+.
Hi there.don´t forget that garmin´s can´t give you the correct sensor power information.
I just purchased a Giant L200 directly from Giant. This is Giants branded partnership with Stages. So if this is a Garmin problem as stated in the reply one would imagine that Giants product would work with a Giant EMTB.the email I received from Giant.
“Hi Miguel,
Thanks for getting in touch.
Unfortunately, this known issue occurs as a result of Garmin's faulty implementation of the ANT+ PWR as well as the CTF standards in manipulating torque inputs from several eBike motor manufacturers, including Yamaha and Shimano.
As the Bluetooth method of taking 'torque-ticks' eBike power measurement piggybacks onto the ANT+ standard, there is no easy workaround to use Bluetooth instead of ANT+ in this case.
Yamaha has been attempting to work with Garmin for a number of years on this issue, yet it appears to be not a high priority for Garmin to resolve and remains broken in the meantime.
Until Garmin resolve this issue, this data will continue to be faulty.
Please be aware that this is not a Giant/Yamaha issue, but we are attempting to help Garmin resolve it.”
It is clearly Giant, but it is easy to blame an other company so you don't have to do anything. With these L200's they are shooting in their own foot, because they can't blame an other brand. My LBS reported the problem with the L200 to Giant, and they acted like it was a new problem. They would investigate the problem, but as usual nothing is happening.I just purchased a Giant L200 directly from Giant. This is Giants branded partnership with Stages. So if this is a Garmin problem as stated in the reply one would imagine that Giants product would work with a Giant EMTB.
NOPE!
The bad power numbers on Giants L200 are identical to those on my Garmin 1030.
???? Giant ????
