Fastfatrob
just got the levociraptor and install today in my 2019 Levo Expert, something is not working right! My speed was 25 Miles, now remove the planetary magnet, and my speed will not go over 17 miles.
I have responded to your email and please can you provide firmware version?just got the levociraptor and install today in my 2019 Levo Expert, something is not working right! My speed was 25 Miles, now remove the planetary magnet, and my speed will not go over 17 miles.
I presume the firmware in motor has set restrictions or limitations on motor revolutions or amp cutoff.Just return from a test ride of 30 miles Ride and max speed was 27.5 (44 km/h)recorded on the Garmin. Re-install and reset the TCU got better than before what was 17 miles (27.2 km/h)top speed. But in position #6 suppose to go over 50 miles (80km/h). Even going down one of the bridges here cuts off at ?28 miles ( 44,8km/h). What can be done?
Please contact me through email and we’ll help get it sorted?So, what else can be done, your system not working as you said it was?
Thank you for your support.It works.?Please follow removal procedure and retry. Often setting to 3 on dial on 1st install will meet with success.
Get ordering as dispatching orders this week.Are there any Lecociraptors in stock at the moment or will i have to wait if i would order one?
ThX for answering!
Instructions should of come with shop dispatch email. Sorry.Just received mine, took 20 days to get to New Zealand, it was like watching paint dry
Fitted to my 2019 turbo levo fsr base model following the PDF I found in this thread as there were no instructions. Set to 4 and took it for a test sprint up the road and back, 118rpm cadence 49.2kph was the fastest I could pedal it.
Great result and very happy, thanks a lot!
Now how do I upgrade the drivetrain so I can go faster without losing the low end gearing?![]()
Please contact me to arrange replacement.My Levocirraptor has stopped working :-(
With only 2 riding days, first the Levo started turning off after few seconds, I thought the problem was the battery wire, so I unplug and plug the wire without success. After few tries, the bike stays on but locked in trail mode and doesn't allow the mode to be changed to eco or turbo.
Any idea what's going on? Is it fixable or should it be replaced?
Thank you,
Yes you can follow the uninstall procedure in the instructions which resets value for restriction.Thank you for the quick answer.
I have made the indicated tests, setting at 3 and resetting the tcu without success.
Now I have removed the levocirraptor to ship it back and the bike remains without speed limit !!! as if it was still installed, I have no speed limit. I have tried to turn on and off the tcu several times and keeping the ON button pressed for more than 10 seconds, and the bike stays un-restricted.
Can't I revert the bike to the original state?. That was the whole idea, to be able to take the bike back to the shop for maintenance or repairs in the original state, but now it is very clear that it has been manipulated. Any ideas?
Dispatching has begun.Hi - has the new stock arrived ? Placed my order 17th of November and can't wait to experience unrestricted Speed on my new Levo ...
Order status will update.I am also waiting on an order from November. Can’t wait to get it. Do they notify you when it has shipped?
Just checked that Status via the link from the order confirmation - says 'awaiting processing' ... I thought dispatching for the orders placed in November has begun ? Can you please check ? ( my order was placed on November 17th - order number #177 )Order status will update.
Thank you for all your custom.
It was a test unit.Just checked that Status via the link from the order confirmation - says 'awaiting processing' ... I thought dispatching for the orders placed in November has begun ? Can you please check ? ( my order was placed on November 17th - order number #177 )
Is it a secret?I do not support derestriction, but I know how to derestrict any 2019-2020 levo. you can dm me for details. but again it is at your own risk. And yes... it works
