2019-2020 Levo (2020 Kenevo) Speed Unlock Levociraptor
TrailwattsUK
Trader
Aug 27, 2018
844
711
Kent
# 1770, shipped 2020-09-24
how about ths unit ?
Thanks for your work and help,
projekt
Please contact directly to deal with orders. I cannot check this forum for everything.
According to tracking it was delivered on the 29th September.
TrailwattsUK
Trader
Aug 27, 2018
844
711
Kent
I've just bought one recently. Not installed or used it yet due to the awful Winter weather.
I've also recently updated the Firmware on the Levo Comp and was wondering if future firmware updates could cause any issues with this unit?
There is an alternative installation method if required should bike not remove restriction.
Moogie
18
9
Netherlands
Anyone have the issue that the turbo levo 2020 with the Levociraptor is not going above 40km/h? when I really try and push hard I can do 46km/h
Chainring is already a 36T in the front so I should be able to do more...Tried all settings but the number 5 is the highest one working.
Tried both reset methods (holding mode and powering on) and (reset 2 times)
restriction is gone as I feel the power until the 40km/h.
Maybe someone has an idea.
TrailwattsUK
Trader
Aug 27, 2018
844
711
Kent
On newer firmware variations setting 5 is the highest available. Also the torque pressure is very light at high cadence so you won’t get the whoosh of low cadence, high torque.
TrailwattsUK
Trader
Aug 27, 2018
844
711
Kent
Remove the Levociraptor,
Switch bike on and ride for a few minutes then turn off bike for 5 minutes.
Install Levociraptor unit (setting 5) and then reset tcu twice.
Moogie
18
9
Netherlands
I just cant get the bike above 40km/h, its a nice speed but nowhere near the stated 86km/h.
I have been on several ebike's tuned, doing an easy 55km/h.
The Turbo Levo is so stable it can do that easy in my opinion.
TrailwattsUK
Trader
Aug 27, 2018
844
711
Kent
Please contact me by pm with your order number.
I’ll send you a unit to test and if result is the same then your firmware combination is the cause and once units returned will gladly refund.
Al Sylvester
Moololaba
Trailwatts has been commissioned to launch and support the new TCU Module designed and built in Italy for the removal of speed restriction on the 2019 Levo.
Check it out at :
Levociraptor
£99.99 delivered worldwide
Many thanks
Hi TrailwattsUK. I have a 2020 Turbo Levo Comp. Can the Specialized software pick up that this unit has been used on the bike? Thank you, Al
568K
