190mm fork on dengfu e10
vancouver rider
26
9
canada
i am ordering 2 zeb ult for my friend and myself haha. so we picked a 170mm. now for the other one. should we go 180 or 190 zeb ult? would 190 be too much overfork this e10?
hahaha anyway sound fun!
PerseverantOne
56
United States
Hope you got the 2023 Version with BUTTERCUP DAMPER system on Debonair+, if you bought the 2.1 ZEB setup only the ZEB can be gutted and upgraded to the Buttercup Damper 3.0 Setup that came out as a 2023 Item but is for sale now.
PerseverantOne
56
United States
if mullet you can go 190 then.
i am doing normal 29er front and back i should be ok with 190? i should be better geometry than your mullet set up?
I am looking to keep with 27.5inch rims, but I need serious travel for big drops, & want it to be smooth. I keep leaning towards the new 2023 Buttercup Damper 3.0 by RockShox, & Fox Grid2, what's the best rear shock for someone like me 5'11.75 height 150lbs? going off an 8foot drop is the goal, without damaging the E-10 Frame. do you think it's possible?
Dirtnvert
1,463
1,695
BC Canada
You might want a boxxer or fox 40 set at 190. At 190 on a single crown fork doing drops chances are youll run into creaky CSU's. Triple clamp all day for drops and at 190mm the axle to crown is the same as a zeb/38 at 180
553K
