Hi. The App does not write GPS data into DB until it detected by GPS sensor. Are you talking about the online dash or statistics?Hi vadll
I'm currently testing version 1.14.69 and see still the same error as in Post #361.
please do not write position Coordinates: 0°N 0°E into the database
if there is no GPS Fix.
0°N 0°E is not a placeholder for none GPS Fix but a Geo Position (Gulf of Guinea) .
When the real GPS position is received (GPS Fix) one occurs huge offset over 5000 km !
Ok. Try the new 1.15 versionHi,
I'm talking about Session Records if there is no GPS Fix then the position Coordinates: 0°N 0°E is entered.
see the preview of the Session Records in the post number #361
the preview shows the first Position as 0°N 0°E ( in the sea Gulf of Guinea)
Newbie question: my bike (Orbea Rise) does not have a display, only a unit with buttons to control the assist. Will the app be able to display the battery level on my Apple Watch?
I have both E-Tube and ST Unlocker apps on my phone, but they're very slow to connect and can't be connected to the bike while riding, so not very practical to use them to check the battery.
Honnêtement, je ne veux pas d’écran et préfère le truc avec juste des boutons. La seule chose que je veux savoir lorsque je roule, c'est le pourcentage de batterie, car l'indication LED est la même pour 100 % et 20 %.
J'ai à la fois les applications E-Tube et ST Unlocker sur mon téléphone, mais elles sont très lentes à se connecter et ne peuvent pas être connectées au vélo pendant la conduite, donc pas très pratique de les utiliser pour vérifier la batterie.
I am in the same situation. Just downloaded the app, it's giving me the battery percentage. All I need now is an android phone with a smaller screen than mineHonestly, I do not want a display and prefer the just-buttons thingy. The only thing I want to know while riding is the battery percentage, because the LED indication is the same for 100% and 20%.
So, does it allow you mid-ride to just get your phone out of the pocket and instantly see the battery percentage?I am in the same situation. Just downloaded the app, it's given me the battery percentage. All I need now is an android phone with a smaller screen than mine
Congrats to the developer, as a retired programmer, I can see all the work that was put in the app.
I just have the tiny doggle. I don't want more. I just take out the phone to see the battery when I want to. (It connects fine with my iPhone if I start the bike and app in the right sequence.) But I set the app to talk to me from the phone telling battery status from time to time. (The watch is too small to use when riding so the phone is fine.)Honestly, I do not want a display and prefer the just-buttons thingy. The only thing I want to know while riding is the battery percentage, because the LED indication is the same for 100% and 20%.
You can do this by yourself by creating a new or modifying existed scheme XMLI am sure it has been asked, but here's a suggestion of upgrade I would really love.
The possibility to add a configurable minimal display (battery usage, distance...). This way we could use a smart watch with ST RIDE.
Is it documented anywhere? Thanks!You can do this by yourself by creating a new or modifying existed scheme XML
Wow!Yes, in this thread
For example
Is this sarcasm?Wow!
I am not much of a "power user" but I taught programming (embedded systems) for 35 years. So I can appreciate the incredible work you put into this app. Thank you so much.
It wasn't, your app is really good. In fact I am about to write a post on my home EMTB group to publicize your App.Is this sarcasm?![]()
