BESST tool PRO
Waynemarlow
1,065
873
Bucks
Guys, having a problem with using Beest. Its the first time I've used this Beest Tool and on this PC. It would seem that the Beest tool will not connect to the controller. I'm pretty sure that the controller is OK, its new ( I need to calibrate it ) and when connected to the Beest tool the controller LED will flash approx. every second.
The Beest tool is reading OK on the PC computer settings and is recognised when plugging in the USB cable. The tool however shows nothing other than the " Power" LED ( motor battery I'm presuming ) and the first LED up from the bottom, the "Test" LED.
At this point I have no idea whether its the Beest tool, the motor cable, or internal of the motor. Any ideas on how to start eliminating which device or cable is creating the problem. I'm using a dealer ID which is recognised by the Beest App.
Thanks.
Waynemarlow
1,065
873
Bucks
OK further info. It would seem its the BESST tool itself. The version I have is BESST.UC 3.0.3 BSF33.05. Should this work ?
I have tried to update the tool on line but neither BESST Pro or BESST will read the unit nor get into the Update section.
Another clue is that the tool powers on ( red light ) and then goes into " test " ( blue LED ).
Any help here would be appreciated.
Thanks.
salvaparraes
17
España
Hola, en la herramienta BESST Pro en la sección Ángulo de inicio, puedes ponerlo en 0, ¿qué opciones tienes indicadas y qué hace este valor?
Moderator Edit :
Hello, in the BESST Pro tool in the Start Angle section, you can set it to 0, what options are indicated and what does this value do?
Please post in English. It's an international forum and the standard language used is English so that everyone can understand and help.
Csubi
7
7
Vancouver
ok maybe you are right. I didnt try 100 current on lvl1.Bu what i think is that they have set a limit on every lvl.For instance 10a on lvl1 12 on lvl 2 etc.
When you change the limit you get a percentage of the maximum set limit of the corresponding lvl.
If we say lvl 1 gets on 100% 10a you can set it to let say 50% and you will get 5a max
How can one tell, what each levels Amperage is set to?
Caio
36
14
Sao Paulo Brazil
Hi Guys,
I was able to update my M510 with new FC 2.0 controller using 10.1 firmware for 48v using BESST PRO following the instruction shared here, all went well, was able to fine tune support and assistance levels for 25km/h. (still have to test outside).
However, when changing the speed limit and saving it, i'm getting this message when updating the max speed, cannot increase over 25km/h into 32km/h ,
I'd like to set 45 - 60 km/h, Is it possible?
Any Ideias?
Tks
Caio
Neeko DeVinchi
1,004
1,326
Hi Guys,
Any Ideias?
Tks
Caio
Your M510 with the controller 'MMG522C3619F802047.1' using Besst Pro can only be set to a maximum of 32kmh.
Whilst I'm aware that Besst Pro allows you to manually type in the speed limit, the values cannot exceed what's in the drop down menu👍🏿
Csubi
7
7
Vancouver
I believe my CAN bus push button programming cable was able to change that on my display to 60km even though the drop down was less.
PitcairN
42
26
Slovakia
Hi Guys,
Any Ideias?
Tks
Caio
Set parameters in Besst Pro with 25 km/h limit and save. Then go to regular Besst and change the speed limit to desired amount, it works for me.
Caio
36
14
Sao Paulo Brazil
I guess DPC 245 is not compatible with old same BESST, seems to work only with BESST PRO,
When trying to connect, it cannot connect, doesn't seems to identify,
Or maybe i'm doing this wrong, only switching to the old display ??
or using cable Flash CAN Programe, i'll try this one once i get the cable.
Caio
36
14
Sao Paulo Brazil
I´ve just tested the bike outside, boost mode, full assist and full aceleration the bike is stupid fast, it seems the full motor potential has been unleashed. OMG
I never thought i would say something like that, but i need to tone down the motor a bit to make it safer, lol:ROFLMAO::ROFLMAO:
Neeko DeVinchi
1,004
1,326
I´ve justed tested the bike outside, boost mode, full assist and full aceleration the bike is stupid fast, it seems the full motor potential has been unleashed. OMG
Alternatively after speaking with racers who use bafang m510 motors, they've explained that they have only modified level 1 and 2. I.e. level 2 gives maximum power and level 1 is the equivalent of a trail mode. Levels 3, 4 & 5 are set to 0 for everything, as they found that having 5 levels of assist unnecessary.
I might experiment with that, as I've never been a fan if having 5 levels of assist with Bafang displays and would settle for 2-3 levels of assist👍🏿
Csubi
7
7
Vancouver
Those are probably UHART motors that are easy to program. The CAN bus need firmware made by Bafang... That's why I'm looking for CAN bus firmwares for G510 / M620 30Amp
PitcairN
42
26
Slovakia
Can motors such as M510 have speed limit setting in controller, not in HMI. UART based motors have speed settings in HMI.
Chris999
South Australia
Hi All
Recently bought a Rever Sport M510 based ebike. 48V based and came with the 10.1 firmware. I'm looking at reducing the assistance level as level 1 seems to be more like Tour mode in Bosch and I would prefer a true Eco mode. Reading the forum, I get the idea that Offline mode in Besst is very limited. What exactly is possible in Offline mode? I see conflicting comments about using python to get past login for Besst Pro. Can someone confirm that this actually works or do I really need a real login account. As you can probably guess I don't yet have the Besst hardware. Any thoughts on where to purchase this, I've seen Ali express but never used this myself.
Also, an oddball and I should probably post in another area, but the trip meter (dpc240) occasionally stops to log distance after a while (not every trip). The ride time is correct, and the speed and motor cutout all work as expected. The corresponding average speed for the ride it calculates is understandably very low. Anyone else experience this? Is the distance computed by the display or is this all done by the controller (effectively the display is like a dumb terminal)? The software of the display is listed as DPC240CI10202.3 if this helps.
Any help appreciated.
Cheers
Chris
Caio
36
14
Sao Paulo Brazil
Hi All
Cheers
Chris
I did a calibration myself last week after changing the motor controller for the new FC 2.0, following the instructions listed in this discussion topic.
BESST PRO Offline does not provide the same tuneability as BESST PRO ONLINE, so you need to run loginpass.py script on Python to log into it, very easy process.
Refer to
Steps:
1o. Download Python3 ; Besst Pro Tool and loginpass.py script at GitHub
2o. Run Besst Pro and procedure described at login Bypass at Github, running loginpass.py script
3o. Plug BESST TOOL to HMI display and computer and read HMI and Motor for calibration.
I´m still playing w/ settings to find the best adjusment, support and accelaration levels need a lot try and error to find the sweetspot, however the granularity of the adjustment is very high, awesome tool to play with.
I bought my BESST hardware at Aliexpress with no issues.
I suggest going through the past posts so you can clarify any doubts in this process.
About the odometer / distance , try to check magnet , wheel size parameters.
Caio
Chris999
South Australia
Refer to
Steps:
Caio
Hi Caio
Thanks for the feedback. I'll be ordering a Besst tool soon. I was trying to find a bike dealer that would initially do this for me, but none seemed interested and only appeared to deal mainly in Bosch. Seeing your comments, having your own unit looks the way to go as it looks like it takes a few goes to work out what the ideal settings will be.
Cheers
Chris
mikenet
27
12
roma
Ciao ragazzi,
Sono riuscito ad aggiornare il mio M510 con il nuovo controller FC 2.0 utilizzando il firmware 10.1 per 48v utilizzando BESTT PRO seguendo le istruzioni condivise qui, tutto è andato bene, sono riuscito a mettere a punto i livelli di supporto e assistenza per 25 km/h. (devo ancora testare fuori).
Tuttavia, quando modifico il limite di velocità e lo salvo, ricevo questo messaggio quando aggiorno la velocità massima, non posso aumentare da 25 km/h a 32 km/h,
Vorrei impostare 45 - 60 km/h, è possibile?
Qualche idea?
Grazie
Caio
devi usare una versione precedente di BESST (non la versione pro), io o ho usato 1.2.23
Hi Guys,
Any Ideias?
Tks
Caio
you must use an older version of BESST (not the pro version), I used 1.2.23 with also dpc 245
526K
