Bafang Go+, is it a new App for all motors ?
Sixdays
31
11
MAN
just look back at your 245 display, there is a version number code behind.
Seems like mine is V2. I wonder is there a way to update the display
Pinkee
15
Does anyone know if the GO+ allows you to set/change your max assist speed limit (through the 245v3)? Just finished my bike and my supplier didn't set my speed limit to what I asked, so I am looking for a more suitable solution to resolve it, rather than buying a besst programming tool.
21,374
Sadly, no.
There's a bafang post in the de-restricting section which should help you. But basically a dongle or a K1 Flash or a BB3.
PLM
22
9
Graceland
ISSUE! New Android Device. Pixel 8 Pro on Android 14.
BAFANG GO+
The app is great and was working great on my ANDROID DEVICE VERSION 13.
On the new update Android 14, I can no longer use the "Set The Personalized Ride" in Vehicle Settings. This is the main part of the app. Cannot access this part to change Parameters. App keeps popping up with error. When I use old device, app works fine. Also there have been no app updates for months. NOT WORKING ON ANDROID 14. Anyone else have issues with Android 14 and Go+?
Sixdays
31
11
MAN
I have DPC245 HMi on version 2
Does anyone know where could I download the firmware to update to DPC245 to version 3 firmware? Or where do people obtain Bafang firmware files? Thanks
clix
186
209
EU
I think this is a HW upgrade, not only SW. So you can't just update version 2 to 3.
bengerman
Magyarország
Thank you for confirming. I emailed 3 different Bafang support addresses about this and hopefully will hear back. In the past, ZERO response to any questions.
I saw there was a update on November 13 to the Go+ app according to the google play store app info.
I have the same problem with MIUI 12.5.3 with new frey evolve neo (M510, dp c245, display v3.0, controller v2.0).
Contacted Kathy at Frey, if they can help I'll let you know. If you know any solution, pls let us know too.
  • Like
Reactions: PLM
PLM
22
9
Graceland
Have you received any response from Kathy at Frey? Any Bafang contacts I have reached out to are crickets. Ugh overseas apps!
bengerman
Magyarország
Hey!
I just had a reasonable conversation with Kathy, I sent them the app-android versions, controller-instrument infos with screenshots, they contacted bafang, we are waiting for reply.
bengerman
Magyarország
Hey everyone!
Kathy (from Frey bike) discussed with Bafang, Bafang guys need to research the problem.
So as Frey bike has motor warranty, Bafang sent a new motor with express delivery, which should arrive in 10-12 days.
We will see if it works, I'll let you know. Fortunate I'm a mechanical engineer..
PLM
22
9
Graceland
Hey everyone!
Kathy is sending a whole motor? The M510 motor?
Tomblarom
145
215
Hey, I also had this "Operation Failed" issue, but on Android 13! Bafang sent me a new firmware file for DPC245 3.0. I will test it on Friday, but maybe it helps you already. Version: DPC245CF80301.2
EDIT:
I flashed with BESST, tested on Android 13 as before and it solved my "Operation Failed"-issue, when opening "Set the personalized ride".
  • DPC245CF80301.2-APP-2023092190DE.bin
spokémon
191
100
Is this firmware to be installed onto the display DPC245 v3 ?
How do I install it?
576K
