LJH
Wilmslow
Permission granted by @LEE. to show off his large frame w/big 36 forks/720Wh build.
Clean and white sleek in color 20.46 kg/45.11 lbs. It's the wet weight with sealant and pedals and loaded with premium componentry, so it won't get too much lighter! 💎🪙🧨🎉
Well done!👍
He's still working out headset issues, so he's not able to ride review it yet. He'll post updates when he's able. Others are likely doing a shakedown ride as I write, and will likely chime in when they're ready too hopefully!
Mine is still a week away or so!
Again, great build @LEE.! 🤛 View attachment 113285 View attachment 113286
Who is producing this frame? Can you buy directly from production plant or do you need to buy fron
The weight of the empty case is 1kg. I think that light models of well-known brands with non-removable batteries do not have such a heavy case. The frame itself is a strong case for the battery.
Who produces the CEF50 frame? Can you buy directly from the factory?
TCFlowClyde
1,235
799
Mesa, AZ
SZZS is the frame manufacturer. Can buy it directly from them via Alibaba.com.
Jean seems most knowledgeable over others. Just tell her you're interested in the CEF50.
  • Like
Reactions: LJH
borysgo2
97
155
Ireland
Hi.
I am going to go ahead and try CEF50 frame. Gathered some information but there are some stuff I am not sure about.
1. From October 2023 supposed to be new front triangle available to accommodate coil shock. The question is how to recognise it ?
Is this a frame with 2024 and UDH hanger in description ? Or just ask someone there to make sure new type of frame is supplied.
2. Another info I tried to get is max front chainring, but I think found the answer, someone is running 38T so all good. Anyone else running 38T ?
3. What is diameter of the supplied 720Wh round battery ?
Any info more than welcome.
Regards
Herculesridesebikes
42
25
Hello everyone. the bike is assembled, some other small things, then on to the real ride.
I did a firmware update. firmware CRX30PC3615E102003.3 works for me. and with CRX30PC3615E102003.2 it doesn't recognize my battery.
first impressions, the engine has a lot of power. only in B mode, after sudden pedaling, the engine shuts off, then starts again after a few meters. and when it rotates constantly, everything is ok, only when the pedal is pressed hard, the assistance turns off.
the weight is about 20.5 kg, I'm adding some other little things, so I hope it won't be heavier than 21 kg.
Frame XL
battery DIY 11s3p 21700 lg 5800mah cells.
fork Zeb 29 select 170mm
Shock suntour triair 210x55 with offset bushing. ete length with the offset bushing is 214mm, so I left the stroke 55mm.
Wheelset Mavic e-deemax mullet s30-s35
Tires prowall casing
front pirelli scorpion enduro s 29x2.4
rear in arrival pirelli scorpion enduro s 27.5x2.4
Cassette 12 spd. 11-52 aliexpress
Shifting Sram gx
brakes Hayes dominion a4, 220mm rotor
View attachment 137822 View attachment 137823 View attachment 137824 View attachment 137826 View attachment 137827
Are you running you offset bushings in reverse? I tried this but found they would eventually spin back around after some riding.
ficorama
318
285
Croatia
I mounted the bushings to extend the length of the shock. now the installed length is approx. 214-215mm. they don't turn to me, when you squeeze them so they stay in the position they need.
ficorama
318
285
Croatia
It seemed the more I demanded of the bike the more I noticed, what I would describe as a momentary disruption of power delivery.
Hello. I started having interruptions in my pedaling today. I noticed that it doesn't show the speed correctly. for example, I'm driving 24 km/h, then it shows 13, then 8, then 24, and it keeps changing speed. and it threw error 21, speed sensor, a couple of times. I think the problem is the bad position of the speed sensor, it's a little too far from the magnet. I will try a DIY magnet. which magnet are you using?
Myalteregohamish
294
229
Vancouver, WA
No speed sensor related issues, or errors on the display. The whole thing dead. I recorded a video and sent it to Lynda. We’ll see what bafang says about it.
calvintys
189
188
Malaysia
i am using this , no problem only once when my sensor screw not tighten enough n it out of position.
ficorama
318
285
Croatia
my problem is that the magnet barely passes over the sensor. they drilled the holes for the sensor wrong. I will try to move the sensor or magnet a little by 3-5 mm. yesterday it showed me error 21 20 times. and the firmware needs to be changed. Linda sent me the e road firmware, because I reported to her that in Boost mode, the engine stops and it shows me the error 09.
voigtkampff
69
62
Poland
have a look at my solution to the sensor position issue in this post SZZS specific CEF50-main thread (initial builds and troubleshooting related only) (strong neodymium magnet glued to the rotor at proper place). The magnet is 8x3-3 variant from this offer 1.79£ 3% OFF|2 50 pcs Strong Magnets Countersunk Round NdFeB Powerful Rare Earth Permanent Neodymium Magnet Fridge Magnets for DIY| | - AliExpress
Yozha
22
7
Kazakhstan
Hi guys.
Has anyone weighed the frame+engine+cranks+battery 700wh 48wt kit (all the kit that comes with the frame)?
I want to pre-calculate the weight of my build
92se-r
150
53
United states
my investigation into battery level indicator jumping by large values continues... I see the contacts of battery XT30 connector are covered by some kind of dark patina. They are supposed to be gold plated so I don't quite understand why this happens but who knows, maybe they are the culprit. The question remains, how to safely clean them when I can't just disconnect this cable from the battery, which must remain charged to 40+ volts at all times? And how to ensure they won't "rust" again?
Most likely a bad solder joint causing excessive heat. I would cut it off and put another on. So this is as i suspected, a high resistance connection.
voigtkampff
69
62
Poland
At this moment I'm under the impression that this might not be a battery issue but rather some metering problem. Anyway, I ordered a bluetooth coulometer to monitor the voltage & current as I ride and I will try recording a movie with the exact moment SoC is jumping on HMI, what are the exact voltage, current and power draw readings when this happens. This will be useful for eventual warranty claims with SZZT. Investigation continues...
The coulometer in question is 24.6£ 4% OFF|BL140F DC 10 100V 0 400A Battery Tester Coulomb Counter Meter Capacity Indicator Ammeter Voltmeter Bluetooth Battery Monitor| | - AliExpress
ficorama
318
285
Croatia
here is the firmware i got from linda
Hello. today I played a little with the magnet, however it interrupted the assistance in B again. after that I installed this firmware and everything is ok. I drove a few km uphill and it didn't stop. although it is e-road firmware, it seems to me that it is not less powerful than before. does not have such a strong overrun. for the moment as far as I could see the max power, it showed 540-550W on the screen
92se-r
150
53
United states
Its not a metering issue, the discoloration of the connector means you overheated that connector. Most likely a cold solder joint. Once you compromise that connector it will just get worse and worse and pretty soon you wont be able to ride at all because it will undervoltage as soon as you draw any current. It is a pretty obvious smoking gun when the contacts are discolored.
Myalteregohamish
294
229
Vancouver, WA
MrFixit
12
15
Thanks TCFlowClyde for starting this thread. I built my CEF50 last year as I wanted something lighter than my E10. I just want to share with those who ride in wet weather (or who uses a hose pipe to wash their bike) something I recently discovered, water builds up inside the rear top yoke (as marked in the photo). I discovered it recently when I tipped the frame forward about 45deg when doing some maintenance work on a stand.
TCFlowClyde
1,235
799
Mesa, AZ
Thanks TCFlowClyde for starting this thread. I built my CEF50 last year as I wanted something lighter than my E10. I just want to share with those who ride in wet weather (or who uses a hose pipe to wash their bike) something I recently discovered, water builds up inside the rear top yoke (as marked in the photo). I discovered it recently when I tipped the frame forward about 45deg when doing some maintenance work on a stand. View attachment 138452
Yeah, I've had to invert (wheelie) off the stand to dump out extra water outta and stick a cloth in there to sponge any remaining. I usually wipe down with a wet cloth unless muddy (which is rare in my area.)👍
TCFlowClyde
1,235
799
Mesa, AZ
Is there a hole in the link? Where does the water go in?
No hole. Just pools up and or drips into the linkage potentially. I used Phil Woods water proof grease prior to putting the rocker arm back and to help reassemble easier to the tight fit. At least that's what I did to minimize water ingress.🤞
529K
