Bafang M600 won t turn on after controler change .
boom boom
22
pattaya
Hello every one here is the problem . I had a m600 bafang won t turn on .
The bike was under warranty so i got a new motor .
With the new motor the bike start with the old one no .
So i decided to change the controler and no the bike won t start even after i change the controler .
So what the next step to check on the motor and what should i change ?
Anyone have a video how to replace the cable interface inside the engine please ?
Thank you to everyone .
Neeko DeVinchi
1,006
1,332
Hi @boom boom ,
The reason why the controller won't turn on is because you need to calibrate the controller to the motor via the besst tool.
Seb G walks you through the process in his video.
Let me know if you need help sourcing the besst tool and getting an account with Bafang👍🏿
boom boom
22
pattaya
Hy yes i know thanks but the best pro don t reconize it because it s not turn on .
When i say not turn on mean lcd screan is off after press power buttom .
boom boom
22
pattaya
darkrym
I have the same issue did you end up finding a solution? I am about to order a replacement torque sensor to replace it
529K
