CeeJay
Hi
(I meant to post here but my rookie mistake means its cross posted in Merida as well. Please use this one for replies and sorry for the..)
I have a Merida e140 with the 8000 motor and until yesterday had the SC-EM800 display which could display speed, cadence, time etc. as well as trip distance and an odometer which started at zero when I bought the bike and has logged all kms since.
Yesterday I fitted a EW-EN100 to connect my (newish) Garmin Edge 530.. Everything went as expected and I'm happy with the set-up.
Naturally I had to remove the redundant EM800 so I added an odometer data field in the screen options on the Garmin when I added the eBike sensor but the odometer value only displays the odometer log from files in the Garmin Edge... there is no data field available to display the motor odometer count in any of the Garmin screen options.
I'm curious to know if the odometer log for the bike is local to the EM800 and will stay at the point it was disconnected or if that value is in the motor electronics and when the EM800 is reconnected it will advance to the kms logged in the motor.
Can the odometer value of the motor / bike be sent to the Edge 530 with the other STePS info.
Cheers,
Chris
Cheers,
Chris
