be the full front package view then![]()
need bigger than that mate!
Endura Spray in XL will fit you. Legs are plenty long enough for 33/34 inseam and there is tons of adjustment on the waist. you will probably have the velcros pulled nearly to the max for 34 waist depending on the type of padded shorts/armour you wear underneath.There’s nothing in the mtb world that will fit you. Either the leg is too short or waist too big.
I'm the same size and finding long mtb trousers has been my never ending quest. Currently I'm using some hiking pants, for someone reason they seem to make them with longer legs.
nah, im genuinely a 34" waist (thats waist not hips, they are bigger of course) come down from at least a tight 36 in the last couple of months.. done it before so historically I know I wont lose any more waist size now.. the gut is slowly going and (ill try this in kg) I was 105 ish kg and now im at 92 and still losing..I'm still lost ..
We work in CM's .. but 34" waist ? I've seen the video's.
Do you measure like hip to hip across the front ? Or work on the Levi's sitting in the bottom of the wardrobe from 30 years ago ?
That's impressive !!nah, im genuinely a 34" waist (thats waist not hips, they are bigger of course) come down from at least a tight 36 in the last couple of months.. done it before so historically I know I wont lose any more waist size now.. the gut is slowly going and (ill try this in kg) I was 105 ish kg and now im at 92 and still losing..
it was clear that if I didnt sort myself out I wouldnt be able to ride if I was working or if I wanted to ride, I would have to be taking time off to do it.
90+ Kgs with 34 waist? I reckon your tape measure has stretched!! ......and most wear the waistband of trousers resting just above their pelvis not on the waistnah, im genuinely a 34" waist (thats waist not hips, they are bigger of course) come down from at least a tight 36 in the last couple of months.. done it before so historically I know I wont lose any more waist size now.. the gut is slowly going and (ill try this in kg) I was 105 ish kg and now im at 92 and still losing..
Don't you talk about Dobby Schwarzenegger like that.90+ Kgs with 34 waist? I reckon your tape measure has stretched!! ......and most wear the waistband of trousers resting just above their pelvis not on the waist
Not everyone is built like a Belsen inmate!90+ Kgs with 34 waist? I reckon your tape measure has stretched!!
Yep, this. The weather here doesn’t often call for trousers but I’ve worn my Leatt MX trousers on the MTB and they work well. Mine come down as far as the MTB ones in the OP’s pic so are not too short. They fit knee braces so knee pads are not an issue.If you still cannot find anything to fit get some MX pants. Less than half the price and twice as tough.........only drawback is they tend to be a bit short in the leg because they are designed to go into MX boots.
using the 1974 exchange rate?I ordered them through Wiggle and the were under $100 so under 50 pounds
Got there in the end, nukeproof black lineb just about fit the pads and are ring enough for padded shorts and 'other things' too!
they are the baggiest fit of any so farThey still look too tight for my liking. I prefer something a bit looser fitting.
I hate the recent fashion of skinny jeans and how lots of MTB pants are so tight fitting.. they seem to be getting closer to the lycra the roadies wear lol
Is that you knob pointing at the chair ?Got there in the end, nukeproof black lineb just about fit the pads and are ring enough for padded shorts and 'other things' too!
spinal tap momentIs that you knob pointing at the chair ?
these seem like the roomiest trousers on the market... my mate was wearing them the other day out riding and he looked like a bloody cossackLoads of room in these.........Endura Spray. I have 34 inside leg, 34 waist (36 waist with armoured shorts) and these are size XL. Leatt knee pads fit underneath fine. Legs narrow only below the calfs but have zips to allow a slightly bigger opening for getting your feet through. The bottoms of the legs are not wide enough however, even with the zips open, to be able to roll the legs up and put knee pads on that way. No big deal...just put the knee pads on first. Leg length is generous.
A shoes rack for ChristmasGot there in the end, nukeproof blackline just about fit the pads and are roomy enough for padded shorts and 'other things' too!
shoe rack is out of sight on the left, its fullA shoes rack for Christmas![]()
fucking brilliant, I laughedView attachment 81299
Was going to make this into a cock thrusting gif.
But you all know how lazy us Ebikers are![]()
