Yea big enough for sure. But is this strong enough to repair a tire(not innertube)? It feels so thinThat patch looks more than big enough to me.
Your concern being that the patch material is not strong enough to stop the split in the tyre from spreading?Yea big enough for sure. But is this strong enough to repair a tire(not innertube)? It feels so thin
Yea its the first tire im about to repair so tbis is all new to me.Your concern being that the patch material is not strong enough to stop the split in the tyre from spreading?
That is a big piece of material, so I'd cut it into two pieces and glue them in place one on top of the other, at right angles to each other.
Still got doubts? If so, I'd go belt & braces and force some rubber glue into the split. There is nothing worse than holding doubts about what your tyre is going to do on a dodgy descent. So if you have any doubts about any of the advice then scrap the tyre (but not before you've managed to source a replacement and actually have it in your possession!)
A fellow rider turned me on to these (Park Tool TB-2). Note that the description says "tubed tire" so probably won't work with tubeless goo. I never go on long rides without them, they don't weigh hardly anything or take up much space but I do bring a tube in case I need to use one.Yea its the first tire im about to repair so tbis is all new to me.
Ive repaired a tire with a plug in the past and that holded for a year untill the tire was worn.
I also found this patch at home ...
This is also for a tire? Or only for innertires
Those areself adhesivepatches for inner tubes.
Yep, I had some like that!FTFY
Yes the transparent plastic gets peeled off last once the patch is stuck down, but I usually just leave it in place as it can be fiddly to remove.Fuk so i should have let it dry and peel off the plastic? Its nowhere written in the manual
I alreqdy have that but it wouldnt seal
Its allmost new tire, and is out of stock allmost everywhere in my sizeJust buy a new tyre ?
Change tyre size and brandIts allmost new tire, and is out of stock allmost everywhere in my size
