Puncture prevention
IndigoUnicorn
234
1,074
Las Cruces, NM
Would you like to open little more this requirement? What is the actual reason? The tube adds too much weight to a bike?
I've had impression that tubeless is initially more secure than with tube, but you can always put tube back in serious punctures.
Just the opposite, is my understanding. The bike is too heavy for the low pressures MTBs typically run in the tires. BUT, again, I know folks run tubeless in their eMTBs. Staying tubed is the decision I made after thoughly discussing the option with my LBS (that is a Trek dealer).
nickfrog
139
75
The overall weight is very similar, the delta is only about 10%. The propensity to run low pressure is a function of the sidewall stiffness, whether ebike or acoustic.
Formulasuper
32
20
Atlanta
Top it up every 3-6 months depending on local temps. You'll know it's time when you rush out to the shed late for a group ride and both tyres are flat.
I thought leaving the valve at 12 oclock was what caused it to fill ip with crud, but that might be an Australian thing? Make sure you have spare cores.
Australian thing!
568K
