I have my19 Levo Comp and just recently I noticed a faint "tick" sound on my bike which I have been trying to trace. Seems to be coming from the back wheel but I cannot replicate it spinning the wheel or turning the cranks on the workstand. It seems to quicken the faster I am travelling. It is quite faint but you know what it is like when you notice a noise...your brain focuses on it!!
I cannot definitely tell whether it is only when I pedal or also on the freewheel because the freehub noise drowns out any chance of hearing it on the freewheel.
I have removed and cleaned the rear brake caliper and even ridden the bike with no brake pads in the back to make sure it was not coming from there...rotor and wheel both look true. Checked the pedals and they are fine.
So I stripped off the cassette and checked the freehub/pawls etc. All good there. I could not strip the axle out of the rear wheel hub cos I do not have a 19mm cone spanner...ordered a set so that's the next job. I did just check the rear wheel bearings in terms of rotation and not completely happy with them. There is no play and they are not lumpy but I have certainly felt smoother bearings......so I am going to change them...and change them for higher quality Enduro bearings. They are on order plus bearing press tools to suit. So meanwhile I stripped and serviced the headset. It needed some tightening but the bearings are good so all OK there.
So some info that might be of use to someone:
Rear wheel hub bearings are 6903 LBLU. Bearings man advised me to get Enduro 6903 LLB bearings (I purchased from Wychbearings.co.uk)
I have ordered KIT 14 ( 6903) of the RRP bearing press tools but not the actual press tool since some threaded bar with a couple of washers and a nut will do the same job. ( Tredz)
Headset bearings are top: TH MR 121 1-1/8 45 x45 bottom: TH MR 170 1.5 45x 45 ( not purchased but Edgesports.uk.com have them if you need them.)
Any suggestions to trace the "tick" "tick" are welcome!
