- Thread starter
- #331
So install any PDF viewer into your phone!Just tried to view manual on the app, but it says pdf manual not available in your system!!!!
Moreover, you can view the manual at www.stunlocker.com!
Install the App, connect to your bike, send a licence request, pay and you'll get it.Special offer: software is 100% free for all EMTB members. You can unlock speed limiter of your bike for free. This offer expires on 06/01/2019.
I know its no free any longer , but how can I get this?
Or find/build a time machine and back to 06/01/2019
Nice. But you have to send it to my email ([email protected]), not to the public forum...I received this but I do not see an option to pay......
email sent......Nice. But you have to send it to my email ([email protected]), not to the public forum...
A reply was sent right awayemail sent......
For some reason it did not come thru, please send again...A reply was sent right away
Sent. Check a Spam/Junk folderFor some reason it did not come thru, please send again...
Due "Shimano Inc" demand the App was renamed to "ST Unlocker"
Features:
- Bike Info
- Battery info (recharge cycles and health %)
- Change Assistant Level, including maximum power
Speed limiter change via:
- Destination market
- Circumference
- Max Speed for each mode (works only with FW <= 4.3.2)
Shimano SM-PCE02, SM-PCE1&SM-BR2 interfaces are supported.
Software was successfully tested on my fresh new bike with Steps 8000 motor, as well as on E7000, E6100 motors with any display controllers (SCE7000, SCE8000)
For FW > 4.3.2 the best way to rise a Speed Limit is to change the destination market to US (32km/h). This method will maintain the correct odometer and speedometer readings.
Latest updates at stunlocker.com
Google Play
It's because you didn't apply the licence into the AppI paid for the Licence but used my wife's motor id by mistake. After I figured out I was trying to program the wrong motor id to my bike, I went to her bike to program it but I can not program or access any of the premium features for some reason.
SCE7000 does not support motor's FW 4.3.2I have a Shimano E7000 motor with a SCE7000 CPU. I have installed STUnlocker app on my Android phone and I am able to change the Assist and Nm for each mode, but from what I am reading on the STUnlocker website you can only change the Max Speed on a Shimano E8000 motor with a SEC8000 CPU.
"Max Speed for each mode (works only for E8000 motor with E8000 display and with a firmware up to 4.3.2)"
When you tested on the E7000, did you try to change the Max Speed setting?
I guess I missed the part on how to apply the licenceIt's because you didn't apply the licence into the App
The instruction is included into the email with the licence.I guess I missed the part on how to apply the licence to the App in the instructions. Could you direct me to them?
Yes.Howdy fellas, is the firmware 4.7.1/4.0.7 Ok to use the STunlocker App please??
What did you try?Same for me, I still can not get mine to work and I have tried everything.
If you didn't pay for the Premium licence for your wife's bike, what do you expect then?It's my wife's bike and nothing will open past the $1.99 app..
I don't think that motor controls speed via Di2 gears. So, if it works for you - it works...Just wondering if what i have done is safe as bike dealer said no chip at all would work with my di2 gearing but this seems to be throwing up no faults at all? The speed is wrong of course etc but thats fine unless theres a way to get it bang on?
If you open www.stunlocker.com you can find information that Windows version is no longer supported.Once again your Windows Version is not working.
Windows 7 64bit.
If you open www.stunlocker.com you can find information that Windows version is no longer supported. Use Android/IOS App.
p.s. You can try to start it in "Compatible mode" or start it "As Administrator"
It's not true. 1.03.19 does not have any restrictions, it was released as a final version.It seemes that in this Version there is a "time bombe" which prevents the Software from being used any more
Yes, I can confirm: You can use keys for Windows version during lifetime
Moreover, according to your screenshot with error, your system does not have drivers for Shimano interface
p.s. The amazing thing... You got a free license for two bikes (during special offer). And after one year you are trying to denounce and denigrate me in a public forum, instead of sorting out a problem or asking for help. Ok, noted!
Ok, let's sort it out. Shimano Drivers are installed, Shimano E-tube Project is running without Problems. As I stated before. The last time Windoes unlocker was used it run without Problems. Before contacting you, I updated to Version 1.0.3.19 but with the same failure.
Software works fine for me, as well as for some other customers who still use Windows version.
I would recommend to find another Windows system (fresh installed system will be a good option, but fresh installed WinXP system will be the best) and try the software on it.
