So, I messed up
ButterSausage
8
Norther Norway
Happy holidays good people
Tried to replace the computer on my Giant Stance e2+ this Christmas and messed up. I ate to much and had a couple of cold ones, but this is no excuse for my foolishness.
The cable disconnected and is now inside the frame. The cable was bent in a very strange way from the factory, and is very hard to handle.
Is there a way to fix this without having to fish it out of the hole in the frame?
20,861
If you can see it then to get it out I'd guess it's a question of patience, ingenuity, patience, no alcohol, and patience. 😉
I agree with 80% of your suggestions :)
Skinny little pointy things ... maybe ..
Or something like a modified drinks straw might slide in and fish it out/ slide over the end and let you manoeuvre it back out through the port.
ButterSausage
8
Norther Norway
Haha, thanks for the tips.
Definetely no more beer.
Gonna give it another go. Tried different kinds of tweezers, but the cable is bent 180°, making it very hard to get out of the tighthole.
Afraid I will damage the cable.
I am sorry to say, but patience is one of my heavy burdens in this life 😅
What if I remove this? (in advance: sorry for asking very n00b questions)
RustyMTB
2,886
6,990
If it were me, I'd remove the battery latch mechanism. That will give access to the cables running above it & will only be held in by the hex bolts on the right & the key barrel on the left
9,597
Those torture looking tweezers looks like a must have
They are called "artery forceps". And yes, surgeons use them to clamp off blood vessels (and other tubes) during surgery. Google the term and you will find loads of different types. I have two, one is a straight set that is about 6" long. I've had it for about 60 years, using them to get hooks from fish's mouths. The other I bought more recently from a local market. It is about a foot long and is curved, really useful for retrieving small items that have dropped into narrow spaces, and for retrieving around corners.
As a suggestion for your original problem: is it possible to loop some wire, or thread, around the misplaced item and pull it out that way. Or lasso it and tighten the noose and pull it out?
ButterSausage
8
Norther Norway
Thanks.
It's quite hard to get hold on the cable, but will give it a try again today.
The frame for the battery lock needs to be removed for better access, but is held in place by two screws (which also is adjustment).
Don't think I have the right tool for unscrewing this little buggers
6,640
5,118
Thanks.
Torx...probably T20 or T25
Stihldog
Handheld Power Tool
3,710
5,278
Coquitlam, BC
Thanks.
Looks like Torque Security T20-T25. You likely need to purchase a small set just to get (1) the right size. I got my set from Canadian Tire, but any tool store should have them.
I also had to get the Torques Plus (5point) for the Bosch CX motor mount bolts. My tool collection is starting to grow again 🙄.
Some of these specialized tools have one function and one use, then sit in the drawer for about a year. Park Tool and Amazon is my friend 😳.
RustyIron
1,874
2,941
La Habra, California
Yeah, they're Torx security screws, which are bloody stupid in this application. Butter, if you can grab the outside diameter with a pliers, loosen the screws and replace them with stainless screws with a normal head. Another option is to take that little tool that you thought was a screwdriver but is really a chisel. Knock out the pin in the middle, converting the fastener from "security" to "unsecure." The diameter of the pin is really small, so it should snap off easily. Don't use one of your good screwdriver/chisels. Use one that you don't care about.
Stihldog
Handheld Power Tool
3,710
5,278
Coquitlam, BC
I suspect that it's the other way round - that you are Park Tool and Amazon's $€£friend, I certainly am :rolleyes:
I’ve had success from “SHOP” also.
I had ordered a few things from the LBS (support local) but they couldn’t give me a delivery date, which usually means 6-9 months. Two castle nuts and an “O” ring from SHOP we delivered to my door that week …when I needed them. I’ve found other bikes things on SHOP also.
559K
