Smashpot fork coil conversion on 2019 Decoy Base
Doomanic
🛠️Wrecker🛠️
8,851
10,636
Just got my Push ACS3 kit fitted to my Lyric by Jake at Sprung Suspension and it’s transformed the bikes DH performance. One of the best upgrades I’ve made, highly recommended.
How much?
KenX
293
249
Briançon, France
Now the fork is moving really well, it's definitely better with some compression damping, before it was not so smooth and the damping made it worse....
Trouble is there's only one setting that is close, 6 clicks in from open, if I go to 7 it's way to stiff and 5 doesn't seem to be any different to fully open!
So a Yari Up has been ordered, watch this space......
Doomanic
🛠️Wrecker🛠️
8,851
10,636
MoCo damper?
I've been playing with mine this weekend and the adjustments hardly seem to make any difference. YariUp is in my future too, I wonder if I can use a C2W voucher...
KenX
293
249
Briançon, France
Yes, original Moco, I remember fitting Ohlins dampers to my road/track car years ago and being amazed that every click made a difference, let's hope the Yari Up is of the same ilk!
Loamranger
205
100
U.K.
I don't know what Jake does, so I can't really comment on "better." But I have HC97 on several bikes, and I've been a customer of Push's for years, and it's the best damper mod they've ever done. You can find great reviews on the web for additional info.
Thanks, I’ll definitely look into it.
akuria
135
58
san francisco
I Also have the smashpot in my Lyrik Ultimate. It took me awhile to find the sweet spot with the damper on it (I am by no menas a fork guru) and also got a couple different spring rates but it is now dialed and can't be happier.
Doomanic
🛠️Wrecker🛠️
8,851
10,636
Out of interest, how much do you weigh, what’s your riding style and what spring rate have you ended up with?
KenX
293
249
Briançon, France
Update:
Still really happy with the Smashpot, so much plusher than air and more grip in loose corners too!
Taking it a stage further I've fitted a Yari Up damper (review here: Yari Up v2 fork damper upgrade - EMTB Forums)
Much more adjustability than the Moco damper, which for me, only had one setting, 6 clicks in.....
The fork feels more composed now, especially over repeated small hits (y)
Going to play with reshimming the bottom-out damper next as I'm not getting full travel (180mm) even with the damper set fully out....
I'm 75kg kitted on a 40lb spring, maybe if the reshimming doesn't work out, I'll drop to a 35lb spring.....
568K
