Product Image: (see below)
Product name: Smart Wifi Plug -- TP-Link HS110
Price paid: ~28€
Score (out of 10): 9/10
Review: This is a review for those of you who take care of the battery in a way that you don't charge it to 100% after every ride, but only when you need a full charge/range. You have many threads on this forum for more details about how to take care of your battery.
So with this smart wifi plug you can remotely control (from everywhere you have access to internet) when your ebike charger will start to charge and when it will turn off. You control everything via smart phone app called Kasa. You can manually turn the plug on/off, set up schedule or count-down timer (from 1min to 24hours) when plug/charger will turn on or off, so if you know your charging rate you can pretty accurate charge your battery to desired %. With model HS110 you will also see real-time power and energy consumption of device which is plugged in. If this plug would also have some kind of history or graphs with measured data I would give it a score 10/10, but unfortunatelly it does not support this (for now). The price is very reasonable too, if you still want to save a few more €/Ł there is also a model HS100 which comes without energy monitoring feature. I'm using HS110 for 4 months now and I can say it works perfectly for this application (charging ebike battery) and is very reliable so you might also use it for controling christmas tree lights.
Price paid: ~28€
