I bet it goes like a rocket ?
I have the impression from the photo that the piggyback IFP chamber is slightly rotated. Is that correct or just an optical illusion?
ok thanks. I think my mate has an X2. I'll have a close look at his and see if the dials being rotated could make enough room on the E160on the fox x2 the negative chamber isn't rotated, what is rotated are all the adjustment dials.
Not sure about the proguard , I got the idea from Sam Hill, he rides the same setup and I thought if it's good enough for the champ il strap em to the beast ?That looks great. I wonder if the large Proguard front would protect the rear linkages the same as your mudhugger has. Anyone done this?
Iv tried to change it but can't (probably is possible I'm just rubbish), I may need to contact the powers that be !So what's your new name going to be ..you surely can't keep the Kenevo handle riding a Whyte ?
I will take some pictures tomorrow and post them up ?Could you stick a close up pic of it on here pls?
They’re not too bad once the spring sunlight means I can shift to mirrored lenses, otherwise they do look very, very special.They reckon most fashion trends start down South before making there way up North ..Im hoping that particular trend gets lost on the way to Northumberland ??
Moss green mud machine ?Was sooo wet and muddy today. But GREAT fun! The muddier the better!
Did about 40kms out and back. View attachment 53634
After years of being “ clipped in “ I went back to flat pedals and I don’t regret it at all, no clogged cleats, no frozen SPD mechs......back to old school ways ?Just taking it off instagram as i'm a lazy bugger. Got bored and wanted to see how weird it would feel not running flats as i had the pedals sitting in the shed from my previous bike. The one thing that stood out was how much easier it felt riding with the motor off, but what's the point of that?Currently torn between the added safety of my feet not coming loose and the added danger of myself not coming off the bike when i need to
Crashing at all sucks......of to the docs the morn, think I’ve got bother with roto cuff in left should after an off last year. Tried to work it off doing physio exercises I used to recover after I did my right shoulder at Hamsterly a few years ago but to no avail.....it’s getting worse with time.It's a debate that will last forever. There are times where i almost crash smashing down over rooty/rocky bits where my feet break loose or going over drops where the bike just wants to disappear below me.
Crashing clipped in sucks.
It all about using the right shoes/boots. With my winter and summer 5/10s on Nukeproof pedals it is almost impossible to adjust foot position once my foot is planted on the pedal ( standing on the pedals).....so the opposite of foot slipping.It's a debate that will last forever. There are times where i almost crash smashing down over rooty/rocky bits where my feet break loose or going over drops where the bike just wants to disappear below me.
I have had that problem in both shoulders ( I believe caused by poor quality original forks on my Levo! Changed to Lyric Ultimate since then and the difference is unreal!) . What I found helped, albeit it takes time, was Deep Freeze cold treatment plus a neoprene shoulder support strap. My ( amateur) take on the issue was that the pain was caused by inflammation of the tendon that passes through the narrow channel of the main shoulder joint bone. The cold treatment helped to reduce the inflammation and the strap prevented unsupported movement which could further aggravate it. The treatment took about 3 weeks. I kept riding!!Crashing at all sucks......of to the docs the morn, think I’ve got bother with roto cuff in left should after an off last year. Tried to work it off doing physio exercises I used to recover after I did my right shoulder at Hamsterly a few years ago but to no avail.....it’s getting worse with time.
