unless your a super duper pro high pivot will make little to no difference. Its a trend though at the moment. I'm more looking forward to what bombardier does with pinions integrated gearbox stuff. ebikes are totally meant to do away with the chain/derailleur system.
Yes that with motor would be perfect.
Norco is making the switch to Bosch. Which only makes sense, as they own Livetoplay who is the Canadian distributor for Bosch.No comments?, I like it- is it no longer ep8/801?
looks like they changed the shock position? The reinforced piece in the front triangle looks new. No more room for 2 water bottles
Wonder who will be left on Shimano?Norco is making the switch to Bosch. Which only makes sense, as they own Livetoplay who is the Canadian distributor for Bosch.
Lots of brands are still running Shimano, and lots are running multiple motor manufactures. Off the top of my head I can think of the following using Shimano.Wonder who will be left on Shimano?
I should have mentioned I was more meaning brands that are only on Shimano motors.Lots of brands are still running Shimano, and lots are running multiple motor manufactures. Off the top of my head I can think of the following using Shimano.
Pivot
Devinci
Commencal
Canyon
YT
Orbea
Cannondale
Kona
Transition
Santa Cruz
Marin
Propain
Yeti
Mondraker
Scor
