New brakes
Rawry
147
78
Cleveland
Hi all,
I am looking to upgrade the brakes on my Trek Rail and have been looking at the Hope 4 V4 brakes. What is the general opinion and what would the price be to supply and fit at a bike shop?
Cheers,
irie
2,060
2,011
Chichester, W.Sussex, UK
Hi all,
Cheers,
What calipers and levers are currently on your Rail?
irie
2,060
2,011
I would like something with a bit more stopping power
Fit larger rotors.
Trek Rail with Shimano M6100 levers, M6120 calipers, and RT76 203mm rotors. Went to Swissstop Catalyst Pro 220mm rotors. Single finger braking, huge improvement.
theremotejuggernaut
305
237
Are your Slx calipers 7120s?
If so, they should be capable of giving plenty of power...
If you've got standard resin pads and cheap pressed steel discs then a set of sintered pads and proper discs will make a huge difference.
I've got Deore 6120s and with some XT ice tech discs, the brakes are stupid powerful.
For a bike shop to supply and fit, you'll be paying full RRP for whatever brakes you want plus say, an hours labour at the going rate.
Rawry
147
78
Cleveland
Fit larger rotors.
Is it a simple job to fit the bigger rotors i am not to good with mechanical stuff?
RiderOnTheStorm
@Rawry It's not a trivial job if you're not mechanical inclined. It's something that can take some research and planning, finding larger rotors that fit your calipers (thickness wise), finding correct post mount adapters for your frame/fork and new rotor size, securing the rotors properly on the hub, learning how to re-align your calipers, have some basic tool set. There are plenty of tutorials on yt that cover these steps which always make everything sound so easy. But keep in mind that brakes are a safety thing, so modifying your braking system has to be done correctly (in professional fashion). You could have your LBS do this for you if you're not comfortable doing it yourself.
Rawry
147
78
Cleveland
Thanks a lot i think its best to let my LBS fit them better safe than sorry.
Healy
318
231
Forest of dean
I have just ordered hope v4 e4 from the bike shop that I got my bike from. Had them for £172 per end. About a hour labour to fit and about £15 for the adapter for the shifter
Stanpipe
80
80
Isle of Wight - UK
Hi all,
Cheers,
If you are intent on new brakes I would consider keeping the levers you already have and fitting Magura MT5 or 7 calipers with Magura hose. You’ll still need a Shimano olive and barb. Both use mineral oil. Done this myself with xt levers. Never had a more powerful brake. 😉
markloch
129
117
NorCal
My Rail 5 ('21?) Came with Tektro brakes. I could "1-finger" them fine, but after riding my buddies Rail with upgraded brakes (I forget which brand) I realized the Tektro's neither stopped nor modulated as well.
I won a raffle with gift cards for a local bike store and bought Magura MT5s. Also picked up Magura MDR-P rotors, though kept them at 203mm. I also bought the clamp 'adapters' to hang the dropper lever and shifter off the left and right brake clamps.
At some point I might go "Shaguro" and get Shimano levers as @Stanpipe did.
Stoneilove
141
230
England
Hi all,
Cheers,
If your budget allows it then id say get the Tech 4 V4 alongside the V4 floating rotors, for me the best brake on the market right now, by far the best for progressive power and for dealing with heat on DH nothing else comes close imho
Rawry
147
78
Cleveland
What size rotors have you put on i am thinking 220 front & 200 rear?
RiderOnTheStorm
220F/203R is generally a good base for full power emtb, all mountain/enduro use. Rotor size depends mainly on your weight and riding type and style. Heavier riders will benefit from larger rotors e.g 220F/220R. Lighter Trail riders would be fine with 203F/203R. But it's not just the size that counts (well, sometimes ;) ). The brake pad material you use plays also a critical role in achieving ultimate stopping power.
jcismo1
45
40
Colorado
A personal experience for me, after I installed 203 mm Shimano IceTech rotors and the IceTech finned metal pads front and rear on my Orbea M10 Rise, was as follows. I used the XTR series spacers also. After riding it a few hundred miles, I took the rear caliper off, to bleed the brakes. The mounting bolts were BENT! I checked the front ones also, only to find that they were bent also. I weigh about 180# and I was on the brakes pretty hard on a few rocky and technical decents. Anyway I put the Galfer 180’s back on, along with the purple Galfer ebike pads and I don’t notice any less braking performance. All I can say is, I’m sure glad the seat stay didn’t snap, from the extra force exerted on it.
KGA109
11
19
Salt Lake City
There are a ton of good options - your SLX 4p brakes are good, but where all e-bikes suffer is the rotor. Its crazy to think that we use the same 1.8mm thick rotor on a 50lb eMTB as we do a 21 pound XC bike.
Check out TRP's 2.3mm thick rotors. They WILL work in your calipers; tolerances are tight but go thicker and bigger on the rotors. I'm biased, but brake pads make a big difference too. Rotors + brake pads will be a big upgrade without swapping your brake set entirely.
Frankie_r
32
14
Italy
Hi all,
Cheers,
If you have the budget, go for Hope. I don’t have them but whoever tries them says they’re amazing…
E-MAD MALC
319
167
EAST SUSSEX
Done exactly the same as you
203mm rotors back and front
Got used to them now, I had to go easy initially otherwise I would have been over the bars
mtnbikerva1
32
9
Mid-Atlantic
Code RSC and HS2 220 rotors will give you only stopping power you could want. And right now you can find them at a super low price.
easy to find replacement brake pads at any bike shop or online.
2WheelsNot4
893
692
Yes, they are.
Until you get a leak in them, or the clamp or lever develops issues or the incredibly small bleeding port gets chewed, then you've got to throw all or lever/caliper in the dustbin for want of a £3 part easily available from Hope..
Plus we've moved on from Henry Ford and his colour schemes.
526K
