I don’t get it, orbea wild for example it is non removable per say.Bosch batteries actually last A LOT !
For integrated,still pretty easy to swap them for a new battery if needed.
They remove the motor firstI don’t get it, orbea wild for example it is non removable per say.
Do you mean you can still remove it?
Okay so it is removable easily but not removable for charging like out of the bike.They remove the motor first
Tires yes, suspension no. But my current bike is Pole Voima. So not exactly pedal efficient short travel eBike. But I can safely say it gets 15-20% more range than my old Wild.Identical bike with identical suspension and tyres etc,?
irie said:Identical bike with identical suspension and tyres etc,?
I’m not quite sure I follow your logic. Suspension platform between those two bikes is not going to make one more efficient with range over the other. If anything the Wild should be more efficient yet the Voima gets more range.In other words. No.
Depends on the money you are going to spend.Alright guys, what would you do in my position? Would you cancel the current order and wait for the new bike? Is it worth the wait?
Maybe that applies to bikes in stock. I'm not sure if it applies to the MyO program. We'll see next week, otherwise, I'll cancel the order and wait for the new model...Imho,buying a bike at full retail when it's being replaced in the same time is a big mistake.
I believe the current model will be heavily discounted from next week.
You could be in the first batch with the Gen 5 if there are no other changes to the wild but Orbea can’t update you until the 30th due to bosch NDAMaybe that applies to bikes in stock. I'm not sure if it applies to the MyO program. We'll see next week, otherwise, I'll cancel the order and wait for the new model...
Yeah, they told me that as well. But in their MyO program, there was no mullet option at that time. And as you said, the frame looked roughly the same...The frame is roughly the same other than the new motor mounts.
There are talks about more travel at 170 f&r and mullet compatibility but not confirmed yet.
If I remember the early reviews, they said you could run mullet, but it’s not recommended. I could a lot of people are asking for the option to go mullet so chuck it in as an option with new motor.Yeah, they told me that as well. But in their MyO program, there was no mullet option at that time. And as you said, the frame looked roughly the same...
You can always mullet a bike but the design of the Orbea Wild might not does not support it.If I remember the early reviews, they said you could run mullet, but it’s not recommended. I could a lot of people are asking for the option to go mullet so chuck it in as an option with new motor.
