Fox 36?? If so it has a floating axle so have you done the initial alignment?? If it is out of alignment and not loosened the axle will forced to one side and seize.
That sounds strange. Not even sure how that is possible.hi, the axel doesn’t go through the wheel at all, even when the wheel is out of the fork.
Probably a prototype axle ..That sounds strange. Not even sure how that is possible.
Either the axel is too big, or there is something wrong on the wheel. Wrong bearings?
I'm just glad the OP didn't use a sledge hammer to force the axle in, as you might've done!
??????might
And Sam's tool of choice would either be a brick or a chunk of stone or something along those lines.??????
WOULD ! ......
It's a tricky one, excitement would have been overruling common sense ... and in my case that wouldn't take much excitement.
I'm sure Sam Pilgrim would have got away with just bashing it through. I'd have been concerned about damaging the thread and unlike Pilgrim I wouldn't have 500 spare brand new in box axels lying around, so I might have taken pictures then run a drill through there just so I could ride it![]()
I'm surprised he doesn't have a special multi-tool for "whacking things" .. like an old crank arm with a seized pedal.And Sam's tool of choice would either be a brick or a chunk of stone or something along those lines.
If it doesn't fit... make it fit!!!
Happy days! Glad you’ve got your bike up and running!Wheel has been replaced and I've taken the beast out today. Loved it.
Blimey. Looks like someone has had good go on that pointing with a power washer!Wheel has been replaced and I've taken the beast out today. Loved it.
When washing it should I leave the battery in or take it out?
It was some excess metal in the hub. They stuck a reamer through it and happy days.Happy days! Glad you’ve got your bike up and running!
You can’t just leave us hanging ? what did the bike shop say was wrong with the hub? (or was it the axle)? We’s gots to no, ya know...
Glad you got it sorted and enjoy the bike. Loving mine and just treated myself to the all important torgue wrench so I can look after it better
Going for Invisiframe? I got some orange annodised valve caps to add a little bling
Mail from a localish BS. 45 mins away.Just wondering if you bought mail order or from your LBS.
