Levo Gen 2 Mixing Slx with Gx
Snrbrtsn
216
167
Uk - Scotland
I have my 2021 Levo comp and wish to mullet
I’m selling my hardtail to fund rear wheel purchase, as a trial would fitting the 27.5” boost wheel with SRAM GX cassette work on slx gear train
Is the spacing the same between SRAM & Shimano ?
Would I have to adjust the indexing
Rear Hub, Hope Pro 4, Sealed Stainless Steel Cartridge Bearings, 12mm x 148mm Boost Through Axle,
Rim, WTB ST i35 TCS 2.0 System, Pinned Joint, Tubeless Ready, 32 Hole
Cassette - SRAM XG-1275 Eagle, 10-50, 12 Speed
Tyre Maxxis Minion SS 2.3, though also have high roller II 2.8
salko
1,305
895
SLO
They should have basically same spacing, but you might need to reindex derailleur. Also it is better to use Sram chain on Sram cassettes.
Snrbrtsn
216
167
Uk - Scotland
Stumbled on another issue, with the disc & centrelock, without adaptor it’s a no go…
Any wheel recommendations?
Would I be correct in thinking I need a shimano microspline hub ?
I‘ve found the Crank Brothers Synthesis Alloy E-Bike 27.5" Rear Wheel ? Any good ?
salko
1,305
895
SLO
If you want to keep Shimano 12sp cassette then yes, you need a wheel with microspline freehub.
571K
