You managed to get the chain ring off without removing the spider on a gen3?! I know it can be done on the prior gens but even Spesh said it can’t be done on the gen 3s.I managed to change the chainring without removing the crank arm as I didn’t have the tool mentioned above
Just remove the pedal and chain ring bolts and the chain ring can be fiddled around and removed over the crank spider
I must say It would be easier to remove the arm and spider but it can be done with a bit of patience
Yes honestly I got chain ring off without taking the spider out, it was really fiddly and tricky mind. This was on a gen 3 carbon levo however having the right tools removing the spider would be easierYou managed to get the chain ring off without removing the spider on a gen3?! I know it can be done on the prior gens but even Spesh said it can’t be done on the gen 3s.
Hi
I have just done this
You don’t need the crank arms but you need the 34 tooth chain ring type t and the cassette etc
I found a “emtb “ kit for a levo you need one that’s 104 bcd
The kit came with everything apart from the crank arm ( it did come with a 36 t chain ring) but I purchased a separate 34 t type t chain ring
A quick note of thanks. Had the LBS install AXS/transmission on a Gen 3 Levo yesterday. Usually spot on shop/guys, but they installed the Brose kit that does not have the 104 bcd, etc.I purchased the emtb kit from leisure lakes and the chain ring from Halfords
Make sure the chain ring is 104 bcd
Hope this helps
