Levo Gen 3 Levo Gen 4 2023/4/5/6 Rumours...
Ou812
845
625
Inverness
Amazing job from Specialized keeping the info to themselves till now !
However there were some repeating details from this thread that could indicate some things like :
150mm rear travel
Not a Brose motor
800w + battery (with maybe an option for a smaller one)
Levo sl style frame
same weight as today +-
Been waiting for this bike for some time now but the 150mm rear disqualifies the bike from being a contender for 2025.
Looking got 160+ and the current leading options are the Wild and new E-riot by Ghost (for some reason not alot of new options with that travel).
Waiting to next month to make a decision with a slim hope for the bike's reveal with added travel.
Some are saying there’s 2 travel options, one being a longer travel version with closer to Kenevo rear travel. I think Spesh is trying to replace two bikes in one go, the outgoing gen 3 and the discontinued Kenevo.
Polar
547
670
Norway
Sound like a good way to save production money if one frame can be customized to fit different use.
mustclime
521
408
New Jerzy
I'm pretty sure the guy on the bike is a Specialized sales rep for Northern California.......
Hard to tell if there is a sidebar like the gen 3 levo?
Picture was taken this week, & he was riding with others on full powerd ebikes.
Needs to learn how to set up a cockpit. Look at the stem and steerer spacers. Long negative rise stem with a lot of spacers. The spacers shorten the reach and rase the bars. The negative long stem lowers the bars and increases the reach. Just get a short stem and loose the spacers and the bars are in the same place without adding a lot of stuff that will flex.
Ou812
845
625
Inverness
All I know is they need to announce something soon. I’ve been going back and forth on just picking up a Crestline frame and doing a build off of that. I held off on the first batch and there’s only a few frames left for the second batch. I wanted to see what the gen 4 was going to be before I made up my mind but I’m watching the Crestline numbers dwindle. If Spesh doesn’t make an announcement soon I’m just going to snag a Crestline if there’s any left.
Chicane
396
360
SoCal
Kind of like what Crestline has done. Same front triangle and 2 different options for the rear triangle/ linkage.
ah1
123
62
Santa Cruz CA
I wonder what happens to this thread when Specialized *actually* announces... It will be strange to start discussing the actual specs on page 60! :ROFLMAO:
Ou812
845
625
Inverness
Crestline made it even easier, no need to change linkages or the rear triangle. It’s based off of a 230x65 shock, you get 161mm travel with the flip chip in ST or 182mm travel with it in LT. You want less travel? Reduce the shock down to 230x62.5 and you’ll get 172mm with the flip chip in LT or 151mm with it in ST. It doesn’t get any easier than that!
DuncanDoughnuts
359
239
Cape Town/JHB/Rippon
Curious if ti will have the charger standard ? or stick to the current specialized plug thing.
Also after watching this I am really starting to like the Bosch Gen5 more and more. And the Vala.
really hope the new motor is better (not power, don't care about that) but the way power is delivered as per the video below.
Chicane
396
360
SoCal
Sounds even better than I thought. Crestline HQ is 2.5 hrs north of me and my LBS across the street from where I work, has them in stock.
Chicane
396
360
SoCal
Except there is a different rear triangle per wheel size.
Chicane
396
360
SoCal
Except there isn’t. There are only 27.5 and 29 rear triangles based on their store page to give users the flexibility to swap between MX and 29er. I’m assuming they have different pivot locations on the main frame for the different frame sizes. Same thing that Santa Cruz does and probably some others with one piece rear triangles to keep manufacturing costs down.
Isn’t that what I just said? Last time I checked, there are only two different wheel sizes, just like you pointed out.
electricbogaloo
225
119
germany
If we charge the battery pack after your Levo ride or Vado ride or after your e-bike ride as fast as we technically can, so it's charging in like an hour to full every day, you're just aging your battery pack way quicker. Meaning two years into it, you may have 20 % less capacity that you would have by slow charging.
Good point! The velomotion test showed that the 600 Wh battery failed in their stress test. People don't realize that current battery technology ages faster the more stress you put on it. Meaning fast charge and decharge with high voltage. At some point the BMS will just switch off the whole pack to protect it from being damaged irreversibly so that its dead.
tonk
28
8
East Sussex
So with brose peak drive 3 bike must look similar to this
Ouzzy
13
15
Some media stuff on pinkbike. I imagine this is the start of stuff relating building up to the launch. It was the same when they launched the stumpjumper 15 last year.
Same thoughts, not mentioned levo Gen 4 for purpose and a lot of talking around engineering emtbs blablabla. But indirectly confirmed Brose peak 3.
My bet is Thursday announcement.
21,096
:cry:
If they've gone this way, it just seems so deflating and uninteresting compared to what they were doing :-(
The "Other" bike .. just read like a cheaper alternative to the Levo Gen 4 they were going to introduce to compete with cheaper brands.
Oh well, lets hope that being Spesh they manage to add something magical to the recipe.
gbcoke
172
182
italy
Choosing Brose peak3 will leave the Levo as another "run of the mil" ebike .
Modern motor but nothing special as gen5 weighs less and will have more or the same power after the upcoming update,not to mention DJI.
I expect Specialized to introduce something a bit more unique. Very close to finding out...
Jun 12, 2020
53
51
lake Tahoe
It is refreshing to see this forum back on track with the Levo Gen4 Levo specs and timing being the focus. I concur, the Pinkbike podcast seems to have indirectly confirmed that Brose will remain the motor platform presumibly the Peak 3 motor (which dispenses with the prior DJI speculation, thankfully). I am hopeful that we will see or hear somthing sooner, rather than later. As I recall the new Stumpjumper 15 was leaked w/ spy photos by Specialized in the early spring, with the unveiling following in April at Sea Otter? I believe the same was true of the Levo SL2 the prior spring? So maybe some spy photos will emerge soon. So early summer 25' dealer availability might be the best case scenario? I have no insider information, just speculating like the rest of anxious US consumers.
568K
