I have 2019 Levo using the Revelation Fork. I am thinking of upgrading to a 2021 160mm Lyric Ultimate. I am familiar with removing the fork for headset service etc but is there anything I need to know or buy extra to fit the Lyric?
I wondered about that...I gurss if it is not hugely longer I could use another spacer. If I need to cut it any tips? I guess the issue is nust ensuring it is cut square?No, it should fit right on. You just need some proper tools to cut steering tube.
I think it's more than 5cm longer so you will have to cut it ... I used pipe cutter tool like this:
As an alternative have you considered upgrading the Revelation internals? It’s basically an oem Pike and you can buy the latest Pike damper and air spring (including 160) and essentially have a 2021 Ultimate. It’ll cost about 1/3 to 1/2 a new fork depending on which damper, rct3 or rc2. I went with the rc2 and it’s a huge improvement over the original. Still, a Lyric ultimate would be the, um, ultimateI have 2019 Levo using the Revelation Fork. I am thinking of upgrading to a 2021 160mm Lyric Ultimate. I am familiar with removing the fork for headset service etc but is there anything I need to know or buy extra to fit the Lyric?
Yes but it would not be RED would it!!!As an alternative have you considered upgrading the Revelation internals? It’s basically an oem Pike and you can buy the latest Pike damper and air spring (including 160) and essentially have a 2021 Ultimate. It’ll cost about 1/3 to 1/2 a new fork depending on which damper, rct3 or rc2. I went with the rc2 and it’s a huge improvement over the original. Still, a Lyric ultimate would be the, um, ultimate
Can of spray paint should fix thatYes but it would not be RED would it!!!
Instead of a Lyric why not the new ZEB?I have 2019 Levo using the Revelation Fork. I am thinking of upgrading to a 2021 160mm Lyric Ultimate. I am familiar with removing the fork for headset service etc but is there anything I need to know or buy extra to fit the Lyric?
You'll also need a star nut and a tool to set it properly. You can try to tap it in but it's a crap shoot without the tool
Just installed two star nuts with bolt and hammer. Like this. No problems with that.
Yes.OK I have the fork and the star nut installer and saw guide so ready to go. The fork spec says 180mm to 220mm rotor. I assume that means it will fit a 180mm rotor with no post mount adaptor and up to 220mm with a 40mm adaptor?
I have the original 200mm rotor. Am I correct to think the adaptor on my Rev fork is what I need for this fork.....so basically the same fitting as the Rev??
On a separate point, what are your thoughts on using a spacer ABOVE the stem? I have seen it suggested that it gives the stem a better grip on the steerer but since the steerer has to be cut 3mm below the top of the spacer on top of the stem only 2mm of a 5mm spacer is actually in contact with the steerer tube...that seems a bit flimsy to me.
Charger 2.1 is fully sealed. No external oil. There’s actually a rubber bladder around the internals which expands and contracts in use. If I remember correctly when replacing the charger 1 on my Revelation it used the original seal head which is more of a guide for the shaft. Your situation might be different if your damper isn’t a charger.When replacing the damper with 2.1 upgraded damper is it correct you leave out the rebound damper seal head from the old damper and then don't require oil in the upper leg?
None of this may be new to some of you but before deciding to replace my Revelation fork I did a lot of research to see what option were open to me to fit upgrades and/or improve it.
The first thing I found out that was new to me was that the compression setting on the top of the fork are Low Speed Compression. I had always thought the settings seem to make little difference to the overall compression/stiffness of the fork, and kept it fully open. It turns out that using a more moderate setting would in fact help the fork get into its midstroke.
I also found out that most users of the fork found that the stiffness of the fork could be reduced by running rebound almost full fast. If you do the classic rebound test with such a setting it is clearly wrong but what seems to the case is that the Charger damper is so heavily damped both in the compression stroke and rebound stroke that it not only adds to the stiff feeling of the fork but also can cause the fork to stack ( not recover fast enough).
I was not aware that both the rebound and compression stroke speed of the damper can be tuned via shim stack on each; and that the factory usually applies a medium tune on both. I suspect if the fork is specified for E bike use that tune is changed to firm?? Even the medium tune is likely to be too slow for a lightweight rider. Altering the tune via the shim stacks is probably not a DIY job but certainly an option if the fork is being serviced by a suspension specialist, and likelt to be significantly cheaper to have done than buy for example a RC 2/2.1 damper.......which may also need retuning anyway.
All of which may only be of interest to lighter riders or riders that are not riding Bike Park but may suggest some alternatives for those that find their fork much too stiff and lacking in small bump plushness.
Thanks. Yes it has transformed the bike. Interesting to see all the 2021 Levos have gone to 160mm up front....obviously after reading my post!!.
Considering now whether to upgrade the rear shock and if so what to go for.
