Knocking sound from within the Decoy frame
Sapientiea
296
194
Netherlands
As an extra; If you tighten the top bolt of the battery first and then the bottom bolt. You also have the change of weird sounds as the battery is a bit loose then. It is mentioned in the manual to tighten the bottom bolt first...but no reason is given.
578K
