Levo Gen 2 Horst link bearing replacement question - resolved (I think)
RebornRider
630
644
NorCal USA
The Specialized schematic shows a spacer washer (part 5) between the horst link bearing pairs. But the diagram appears to be showing the carbon part, because my alloy part has a built-in ridge separating the bearing pair. (Which makes pulling the first bearing a ton of fun!)
- Does that mean I should not use the spacer with my alloy horst link?
- If I use a spacer, on which side of the built-in ridge should it go?
- Or does the alloy part use 2 spacers, 1 on each side of the ridge?
The bearings are #2 and the chamfered washers with seals are #4. That much is clear.
Weeksy
438
451
Reading
I'd say you're correct, the built in ridge is the 'spacer' in your bike. Anything else would offset the alignment as well.
RebornRider
630
644
NorCal USA
I went back into the garage this morning with a calmer head, and realized that the spacer (part #5), fits inside the ridge that is built in to the seat stay. I don't understand why the spacer is needed given that the ridge keeps the bearings separated, but I don't think it is hurting anything. I'll reinstall the spacer.
549K
