RebornRider
I pulled my headset apart to address a creaking issue and discovered that the lower bearing has a LOT of surface rust where it interfaces with the frame (carbon frame). Both bearings operate smoothly, but I ordered a replacement headset because of the surface rust. So, ...
Would you install the replacement set right away because of the surface rust, or save it for the day when the current bearings get a little bit crunchy?
