thats good to know...taAt least the one mounted on the Cube, I can confirm, has a rubber gasket installed around the entire perimeter.
Yes new screen and software are coming, not sure on ETA.Just catching up on this I am about to go to a newly released Bosch gen 5 powered bike am I right in thinking the display might be upgradable and I won’t be stuck with the retro led display? I’m amazed they are still using this!
New display or 100Nm?Sounds kind of disappointing…..
Display for me. Could care less about the 100nm. Blasting up a fire road or on paved roads isn't exactly something to brag about.New display or 100Nm?
Yes, that's exactly how it look like. Would be really disappointing.Das Display klingt wie ein Kiox 300, das so konzipiert ist, dass es in den Rahmen passt. Wenn das der Fall ist, gebe ich mein Geld für etwas anderes aus.
Looks like the one I have seen. A navigation possibility shall be givenDies sind die Produktfotos, die Bosch der FCC vorgelegt hat.
Yes, from the manual @gio_se shared above it does have the same limited navigation function as a Kiox 300/500.A navigation possibility shall be given
Yes, it’ll have a color screen, and from the size, I’d say it’s pretty much the same as the one on Kiox 300.Yes, from the manual @gio_se shared above it does have the same limited navigation function as a Kiox 300/500.
But the Kiox 400C is a full controller and replaces any other controller plus the display capability.
Is it a color device?
